Hi
Do you guys use either of the above on threads for maintenance of your bikes? If so, which do you normally apply to common serviceable threads?
Also, and preference on which product to use?
Thanks.
For me - loctite on safety critical bolts - disc rotor bolts. coppaslip on everything else threaded.
copper slip to parts that dont move but you will want to remove one day - Bottom brackets headset cups [ frame side] etc - stops them seizing
Loc tight dont use but perhaps chainring bolts??
Use quite a bit of blue Loctite on components, even things like BB cups where it says 'don't use threadlock'
Copaslip great for the back of brake pads although someone will along in a minute to tell you how it migrates through the backing plate and contaminates the friction material.
Loctite on anything you don't want wandering out on it's own: disc bolts & pivot bolts being the main ones. You can usually spot which one's the manufacturers think should use it as they come with loctite already on the bolts so you'll see it when you take it apart. Copper grease on everything else.
Threadlock only goes on chainring bolts for me. My other threads get copper grease, and I use waterproof grease as "assembly paste" on stems etc (as well as in bearings).
Not too fussy about which products.
Sometimes use copper slip on BB and Pedals.
I wouldn't use loctite on any bike bits, why would you? Just tighten them correctly.
once put loctite 271 on my chainring bolts.
only to find
It is only removable once cured by heating up parts to 500°F
To try (unsuccessfully) to prevent Middleburn spiders from cracking. I'm a serial dropper of steel chainring bolts. Must be my unique riding style.
A correctly assembled and maintained bicycle needs neither of these products, only used by bodgers to cover their sloppy technique or manufacturers to cover their proverbials under 'fit for purpose' regs
No a bike doesn't need but helps in removing BB etc.
That's incorrect.
Shimano hubs are noted for their wandering cones and lock nuts, only Loctite seems to cure this.
In addition, one should lube all torque sensitive threads because otherwise friction might give a false torque reading and correct tightness won't be achieved.
And then there's the risk of galvanic corrosion between dissimilar metals, copper slip greases prevent this.
I disagree. It's good practice and in the riders interest to thread-lock safety critical parts such as brake rotor bolts, calliper mounts etc. Even the most rigorously maintained bike can have items come loose on long rough rides.
I also thread-lock my jockey wheel bolts as on the XT Shadow you can't do the lower one up tightly if you want to leave a gap between the plates.
