lightweight but wid...
[Closed] lightweight but wide bikepacking mat
I have a Thermarest NeoAir XLite currently which is v light and packs v small, fine for overnight but the lack of width bugs me on longer trips! I generally sleep on my back but there's no room for elbows on this mat!! Looking online some people are not bothered by this, some are - and there are some creative solutions ranging from sleeping with arms crossed like Count Dracula to using shoes as elbow pillows! I think I'm just going to get a different, wider, mat though, probably a rectangular one (as the aggressive taper definitely exacerbates the problem).
Any recommendations? Got to be wide, comfy & ideally a similar light weight 350-500g ideally. Just looking online at specs, etc, Exped SynMat UL LW looks ok, as do Nemo Tensor Wide & a couple of Big Agnes wide ones (but they are expensive!)
Posted : 24/04/2019 10:59 am
I am a very active sleeper and what has made a big difference to me is to use 5mm closed cell foam as a tent footprint. Its about 100G more than a conventional footprint for my tent ( but much bulkier) but means the whole tent floor is warm and comfy! a great help when I thrash about and end up off the sleeping mat!
Posted : 24/04/2019 11:05 am
I've the standard width Exped mat and it's just wide enough for me, 42" chest but I'm a fairly static sleeper and tend to sleep on my side. The wide version would definitely be enough room, there's another 15cm. The wide version seems to add about 100g to the weight of the standard width.
Posted : 24/04/2019 11:14 am
Hmmm interesting... I take it this is something you got & cut to size yourself? Where did you source the foam from?
Ta, yeah that's similar to the one I'm looking at, expect rectangular rather than tapered (I reckon you lose quite a lot of width with the taper which is part of the problem with the Thermarest one I've got currently).
found the foam on t'internet. sorry no link and yes I just cut it to size myself. It needed to be creased so it folded up concertina style ( rolling made a silly shaped package) but its still as big as if not bigger than an old skool karrimat
Posted : 24/04/2019 11:19 am
I've never used one but I've been looking at the Alpkit Cloudbase as I have the same problems when sleeping. The Cloudbase seems a bit wider and without the taper unlike my Neo air so thought it might be worth a try.
Posted : 24/04/2019 11:26 am
The Cloudbase has a small taper.
My arms fall down the side of mine if I'm on my back but I'm a side sleeper so it's not a big deal for me.
Posted : 24/04/2019 11:34 am
Ahh, thanks, I'll stick with my neo air and just sleep on my side then ๐Ÿ™‚
Posted : 24/04/2019 1:25 pm
Sleeping on your side is better for anyone camping near you too...
Posted : 24/04/2019 1:36 pm
Have a look at the klymit static v as v wide and great for side sleepers.
I've one and been impressed. Not sure on weight though.
Posted : 24/04/2019 3:29 pm
