Lightweight 10 spee...
[Closed] Lightweight 10 speed Road Cassete
My current lead weight Tiagra 12 -34 (I think) which weighs a ton is getting worn so this is a good time to upgrade. I'd like at least a 30 if not bigger large sprocket but one that is still lightweight if it exists? Any suggestions?
Posted : 13/05/2019 10:01 am
Looking at CRC, it seems that there's the Miche Primato at 30T then the Tiagra for 32T and 34T maximum cog size. There's 30T in the Ultegra range.
Posted : 13/05/2019 10:13 am
There was briefly a Tiagra 12-30, 10 speed cassette (HG50 IIRC) which I have fitted to my bike at present, and when I went looking for a replacement the closest available thing as a much more expensive Ultegra...
Of course there's nothing stopping you looking at MTB Cassettes, an XT 11-32 is probably more reasonably priced than a 6700 Ultegra equivalent and probably a sensible weight...
Posted : 13/05/2019 10:35 am
Nothing to stop you using SRAM or Sunrace if they are lighter. Look for the ones with the larger sprockets mounted on an aluminium spider.
Posted : 13/05/2019 12:31 pm
