Lifeline Essential ...
[Closed] Lifeline Essential Torque Wrench- Dumb Question
 dpfr
[#6788218]
OK so I am the proud owner of this torque wrench. I can alter the setting but but this appears to have no effect at all on the torque actually applied, which is humungous at all settings.
I have even been reduced to reading the instruction leaflet without making any progress.
Before I make an idiot of myself by taking it back to the supplier becuse it is faulty, am I missing somethig really obvious, like a lock?
Can anyone who has one of these advise please?
Posted : 17/01/2015 9:57 pm
I've had a faulty torque wrench (not Lifeline) and returned it without a problem
I've also got one that only sets torque for a RH thread (it's meant to be like that). If you use it on a LH thread (BB cup) it just keeps tightening
Posted : 18/01/2015 6:28 am
Not sure if this is helpful but with my torque wrench the actual ratcheting wrench bit does not adjust.The torque is adjusted my means of a sprung-loaded mechanism in the neck of the wrench. When you reach the set torque, the neck flexes slightly - only by maybe 15 degrees or so. You can carry on tightening if you fail to notice this, so it's important to tighten slowly so you notice the slight flex at the given time.
This might not apply to all torque wrenches though.
Posted : 18/01/2015 11:31 am
Just looed at your wrench online - looks identical system to mine.
Posted : 18/01/2015 11:33 am
 dpfr
Thanks very much. I understand it a bit better now and think it probably is working but will fiddle around some more before attacking some expensive new carbon with it
Posted : 18/01/2015 4:55 pm
Other minor and possibly obvious thing to say is don't leave the wrench tensioned - reduce the torque to zero between uses.
Posted : 18/01/2015 6:12 pm
