I have a 2018 carbon stumpy, which has a standard bolt thru boost axle. What i'd like is a lever type (sort of twist and remove with no tools) axle for it.
Is the spesh axle bespoke/proprietary? It's got a sort of conical collar which sits into a chamfered recess on the frame. Not sure if another manufacturers standard 'maxle' or whatever name would work?
I can find replacement bolt in axles that use a tool to tighten, but not twist release style.
anyone done this?
We have both on the 142 x 12 rear, depending on the model depended on which they fitted, however on the 148 x 12 boosts all ours are with the hex head to remove it. When we queried it we were told that it was part of the SWAT system and designed in conjunction with the SWAT multi tool.
DT Swiss made them for the older Stumpy's & Enduros, they may make them for the new ones?
This looks as if it will, worth giving them a ring and see if they know
https://www.neviscycles.com/shop/products/axl-my16-17-sbc-rear-thru-axle-with-lever-148mm-x-12mm
Part no S170200009
ok, thanks for that everyone. I was under the impression that it might not be something i can get, so thought i'd consult the hive-mind.
The bolt in is just a bit of a pain, as i'm often putting the bike in the back of a car/van.
I'll check out those options.
I have a spare new one. boost 148.
(well 5 rides old)
Pm me if you want to swap?
Correct me if I'm wrong but if it's conical, it's the Syntace X12 system, which has been used extensively by Specialized and Cube to name two for years!
Syntace themselves, DT Swiss, Novatec, KCNC, Specialized and Cube branded axles (I use a Specialized branded one for a Cube bike because it was cheaper) are available for this standard. German retailers generally have a much wider selection. Unfortunately the boost ones are fewer, further between and more expensive!
It’s an x-12 axle, I swapped mine for a bolt in. If I can find the original lever one I’ll give you a shout but no idea where it is.
£40 for a dt Swiss one, Amazon have them in stock. They’re usually around £20-£25 but not in stock with the usual suspects.
fair divide between 'lever lovers' and the rest!
I USED to love QR levers, but my stumpy came with teh neater/lighter allen ones, and I'm quite happy with those nowadays!
DrP
fair divide between ‘lever lovers’ and the rest!
DT Swiss do a thru-axle with a lever that unscrews, so you can lose it somewhere!
I don't buy that because the Enduro comes with either hex or lever depending on which model and both have SWAT.
So, thanks for this info. It's definitely an X-12 axle then... as i can find those pretty easily.
@pastcaring - i'll send you a PM.
