lets talk frames ad...
[Closed] lets talk frames advice needed
Right I've a 2007 trek fuel ex7 with a good smattering of decent kit. that I bought this time last year after needing a full bounce after some surgery.
I'm just not getting on with it, I find it too short and with the 130mm forks it is very snappy especially when the forks are working. So I'd like a reasonable 2nd hand frame that I can swap my gear over too.
So any suggestions. I am not a gravity fiend and just enjoy trail riding and do most of my riding round rivvy but do go out and about.
Posted : 02/12/2014 8:34 pm
 nuke
So if you sticking with the 130 forks and you find the fuel a bit snappy, im guessing a 120mm (as per the 07 fuel)/130mm slacker 26" frame...well based on the standard "suggest what you have", I'd say a cotic hemlock with 120mm rocker fitted
Posted : 02/12/2014 8:41 pm
What did you ride before the ex7 that you liked?
Posted : 02/12/2014 8:46 pm
I rode a 1998 Saracen kili team, it's still on the rigid straight forks. Brilliant bike.
I managed to high side it and broke my pelvis. Hence the full bounce. I find it weird on the full bounce but needs must.
I think the head angle is 69deg so with the 130s it's. A bit pitchy.
Posted : 02/12/2014 8:53 pm
A newer Fuel EX?
I demoed a 2013 version and really liked it. It was pretty stable going down some technical stuff. I think the newer one is probably a degree slacker.
Or Giant Trance,I think that came with a 120mm fork. It would have to be 2nd hand as lastest ones are 27.5 wheel size.
Posted : 02/12/2014 9:11 pm
