I've been running Frogleggs for ages now. No issues with their ability to stop, but there are issues.
1) to remove the wheel you need to squeeze the pads together to release the straddle wire. Only thing is I can't squeeze them enough to loosen the wire?
2) They move in an arc so they point a bit skywards, then curve in and touch the pad.
3) There's zero toe in
4) And they do tend to move about, I have some weirdly worn rims.
What's better, Shimano?
i got some older trp cr950, dont think they suffer these issues. but if i were buying again i might try some of their newer models or some mini v
For the low price of mini-vs I'd recommend trying it... (IIRC I paid £9 an end plus a little more for v-brake noodles with a barrel adjuster) I'm not a proper cross rider mind, but I found no real downsides and the performance even with standard pads is excellent, better than any canti I've used. Mud clearance looks inferior but in practical terms is much the same (the pads and stalks still cause the most clogging, same as cantis, the arms don't make much difference if any)
Main downside is that you need to fanny around with cable tension to remove a wheel, the clearance isn't enough to undo the straddle wire. But with an inline barrel adjuster that's no real bother.
Have been running mini-Vs with travel agents this summer and will be trying them in some central league races this season. Plenty of power and although the travel agent decreases force a bit, it has actually improved control / modulation. I imagine my tubeless setup is going to fail me before the brakes stop working!
pid see you in the League.
TRP EuroX
Tektro cr720's are what you need !!!!
Avid shorty 4s seem to work very well; I used them for the last 2 years 3 Peaks races.
Like all cantilever brakes, they reward careful set up.
The advantage over the more Euro-pro sticky out cantis is that they don't stick out as much...
I've found the Avid Shorty 6 really good as well. After trying to get some new ones for ages and having to live with short on the front and Tektro 720 on the back, pleased to have found them at On One for £20!
The Tektro cantilevers are good, although I've recently replaced them with Campagnolo cantilevers, and the old ones are going onto my old islabike when I rebuild it with Centaur as the original 8spd Mirage has finally worn out. Herself has FSA SL-K cantilevers which are really solid. Both the FSA and the Campag brakes have adjustment at the brake itself which makes little tweaks really easy to do.
Avid Ultimates, they are called the ultimate for a reason, best canti's I have ever run on a cross bike, nice and adjustable, option to run them wide or narrow, easy cable release and with a barrel adjuster as well to adjust the straddle should you need to just nip it up a bit to take up wear in pads.
Ultimates are awesome.
What levers are you using? Cane Creek for example.
I use levers with the little button that slackens the cables, but those are levers without the gear change.
I couldn't get my frogglegs to work satisfactorily so they went and I now have TRP CX8.4 V brakes which are not only fantastic for feel and stopping,but also I can split them just as fast as the cantis to remove a wheel with the noodle.
Oh and I have a 2 pairs of boxed, unused swissstop RAT yellow carbon pads if anyone wants them, £25 plus post.
trp cx are fantastic, but for regular cx racing they dont have the mud clearance which kills your race (this happened to me after the peaks)
you can get some trp adjustable (toe in) holders for the pads. this might help
I have just moved to trp eurox which look better made than my previous frogglegs. the straddle adjuster lets you wind the staddle loose (if set up correctly) which will make it easier to remove your wheel. frogglegs might have this feature too - can't remember
The shimano cx70 and avid ulti's look a lot more simple to set up and maintain. trp, froggs & avids look like they have slightly better clearance than shimano (only tiny tho).
there are some other cheaper brand which crc sell they look like they'll do the job too.
have a look at hargroves for good trp prices!
Anyone tried Planet X Frogs Bollox?
Funny enough I've logged on today for the first time in ages to start a similar thread..
I've got Avid Shorty's on at the moment but same problems mentioned above. I did try Mini'Vs but had the clogging problem..
Should I go back to Frogs legs and just put up with the fact they are made for 'slowing down' not stopping...
Or do I go for a set of the TRPs..
[img]
[/img]
Look fantastic and according to mates who have them fitted they work fantastic.. but £100 as set.. £200 is half-way toward a new frame with disc mounts (which I was considering anyway..)
The TRPs clog exactly the same as their equivalent Tektro BMX mini-vs. Though in my experience it's not an issue, when I compared the mud clearance with my shorties it was pretty much identical... The straddle wire was closer to the tyre but that was a non-issue, everwhere else that it looked like there was less clearance, actually the fork was the limiting factor not the brake.
Andy,planet x had them for £70 pair delivered.
I've tried various bikes on my cx xommuter - avid shorty's, mini v's, proper v's with travel agents, frogglegs. And the only one I haven't replaced is avid ultimates, they really are fantastic.
the trp cx are amazing. but if you race they will kill your race. they dont have the clearance like canti's do. I know this from experience
