Leg Strength
[Closed] Leg Strength
i have crohns disease and recently have been having a flare up,resulting in no cycling in about a month and a half.what little fitness i had has quickly left me.
so my question is what would be a good way to keep up my leg strength when house bound and not well enough to go out cycling or go to a gym.....
any tips or idea's would be greatly appreciated
many thanks
craig
Posted : 09/10/2012 7:05 am
Try and do some work that involves the things around your home. One legged step ups on the stairs, one legged squats (maybe with some weight in a rucksack), lunges, calf raises (with your heels hanging over the edge of a step).
Posted : 09/10/2012 7:33 am
thanks crapknees......will try those out
Posted : 09/10/2012 7:38 am
ass to floor squats
tuck jumps
squat jumps
jailhouse squats
burpees
repeat until you're a heap on the floor
Posted : 09/10/2012 8:06 am
Pliometrics. A quick Google will find you a video session.
The P90X version takes about an hour, and you will feel it the day after.
Posted : 09/10/2012 8:29 am
are you ok to sit on a bike? a turbo and a slick tyre at the back might be ok?
Posted : 09/10/2012 8:35 am
wwaswas im ok on the bike just if havin a flare i need the loo a lot but if in house shouldn't be a problem,just a lot of money for a turbo trainer
Posted : 09/10/2012 8:37 am
It's difficult to quantify 'a lot' for other people but they come up on here for £60-£80 fairly regularly.
It's a good way of getting aerobic exercise indoors rather than just doing strength work.
Posted : 09/10/2012 8:40 am
thanks i'll keep my eyes peeled for one
Posted : 09/10/2012 8:46 am
I think I saw a CRC ad the other day for a Tacx turbo trainer reduced to £80 or keep your eyes peeled for bargains on eBay.
I was given a series of leg exercises to do a while back by a physio...
- lay on back with knees bent & push hips off floor. Keep a straight line with body & thighs, then lift one foot off the floor to straighten your leg. Keep back/hip/thighs aligned. Hold for 10 & swap legs. Do pyramid of 10secs down to 1 & back to 10.
- Lay on floor with feet raised off floor on a chair/foot stool and keep straight line between shoulders & feet (hips off floor). Lift one leg off, similar to above exercise & do same pyramid set.
- stand side on, on bottom step of stairs with one leg overhanging. Keep toes of overhanging foot raised to stop you bouncing off your toes & do one legged squat so heel touches floor. Try to keep as straight as possible.100 reps each side.
- same squats as above but facing stairs, not side on & do one legged squat so hanging leg comes backwards off step. Same reps.
- take 1 shoe off , so that foot is off the floor. Swing leg backwards & forwards in a smooth, deliberate action. Keep body still & hips level.100 reps each side. Will probably get to 70 or so before it starts burning the outside of your hips. Apparently good for hip flexors.
I was told to do all reps required. If you can't hold form, have 2 mins rest & carry on.
2 mins rest between exercises too.
Posted : 09/10/2012 9:01 am
