Lefty max rotor siz...
[Closed] Lefty max rotor size
Does anyone know what the maximum rotor size for a Lefty Speed DLR is? Can't find the information on the Cannondale website, and am considering going up to a 185. Will I die?
Ta,
Andy
Posted : 08/02/2011 12:00 pm
185 will be fine. I run a 183 on my Lefty Max.
Posted : 08/02/2011 12:17 pm
can you run a 203mm?
need stopping power on my 29er conversion
any links to cannondale pdf's?
Posted : 08/02/2011 12:20 pm
Ask on the cannondale mtbr.com forum. Am sure you will get an answer in no time.
Posted : 08/02/2011 12:23 pm
I'm pretty sure I've run a 203 on a lefty max without dying (s'been a while but the disc should still be on the wheel if you want me to check), if that helps any?? No idea about official recommendations though
Posted : 08/02/2011 1:03 pm
ChunkyMTB - Member
Do you use the MTBR forums much Chunky? Lots of knowledge yes, but bloody slow replies. I can check 3 fourms on there once a week ,and still not miss anything.
Posted : 08/02/2011 1:09 pm
 spw3
I ran 180 without issue.
Posted : 08/02/2011 1:11 pm
Lots of manuals to inspect via these links:
Holyzeus - Member
Here http://vintagecannondale.com/cannondale/headshok/headshok.html
and here http://www.eighty-aid.com/index.php?id=7&L=1
HTH
Posted : 08/02/2011 1:58 pm
Zippy, depends which forum really. Turner for instance is really busy with 100's of people viewing. But something like Cannondale will be a lot quieter - even so there should be some C'dale geek on there to answer quickly enough.
Posted : 09/02/2011 8:43 am
One thing to check is that the rotor still clears the boot at full compression - I had to replace the boot on my lefty as the old one had cracked, and the new one was a different shape at the bottom.
On the workstand everything looked fine, but I kept getting grease on my rotors when riding - I realised that under compression the boot touched the hot rotor and got cut, eventually leaking lube onto the rotor!
Posted : 09/02/2011 1:10 pm
203mm on my Lefty Carbon Ultra (converted to 29er), no problems. Pretty sure the blurb said it was fine.
Posted : 09/02/2011 1:13 pm
