RP23 boost valve &q...
[Closed] RP23 boost valve "squelching"
[#2449265]
I recently bought a second hand bike and all is good but I'm not sure the shock is quite right. It holds pressure ok but every compression makes a squelching noise. Is this normal for a boost valve shock or does it need a service. Thanks for any help.
Posted : 08/02/2011 12:03 pm
Probably just hearing the various damping circuits.
Posted : 08/02/2011 12:19 pm
 LoCo
If the shock starts behaving strangly, inconsistant damping e.t.c it probably blown the seal between the oil/nitrogen chambers, and will need a service.
They also squelch a bit at the very start of the compression stroke, which is the fload fluid going through the transfer port between the positve and negative chambers of the air can.
Posted : 08/02/2011 12:41 pm
Could be suck-back? A service will sort it out.
Posted : 08/02/2011 12:48 pm
