Learn to Manual
[Closed] Learn to Manual
After lurking on the last couple of threads about manuals I went out to start practicing last night.
Total skillz failure, on about the 5th or 6th attempt the bike went over the top, I failed to step off, and landed flat on my back... It was so quick, and then I couldn't get up for a good 5 minutes.  I've since consumed many many mg's of every painkiller I could get my hands on, and had a GP consultation to check me out.
I'm just glad I was on grass and not concrete !
Posted : 11/09/2018 10:27 am
LittleNose,
Flats or clipped in?
Posted : 11/09/2018 10:32 am
flats... I think probably I'm just to old and slow
Posted : 11/09/2018 11:11 am
When I take the dog for a cycle ride, or my son, or both, I practise my wheelies.
My plan is to master the wheelie before moving onto the manual. I'd like to learn to bunnyhop properly after that, I can manage about 3 inches at the moment which isn't particularly impressive
Posted : 11/09/2018 11:20 am
am seriously considering buying of of these to learn safely :
https://sender-ramps.com/collections/toys/products/sender-manual-master-machine
i wonder about rim damage on the back wheel though..
Posted : 11/09/2018 11:29 am
But you need to be moving to learn to manual, that's just hoiking the bike up and balancing on the back wheel for a bit while the bits of wood hold you vertical. You don't even have to learn to balance left and right! That's stabilisers for adults, right there 😉
Posted : 11/09/2018 11:38 am
Iainc, There is no danger to the wheel, I made one and it is really easy to balance on it, pretty pointless compared to actually trying to manual.
I know you won't believe me and order one any way, so enjoy your new bike stand.
Posted : 11/09/2018 11:41 am
^^^^^ yeah, I do suspect it could be a bulky dust gatherer 🙂
Posted : 11/09/2018 11:43 am
Before this thread I actually thinking the same of having a manual machine but the cons outweighs the pros so finally decided not to do it at this time.
From the majority of suggestions I slowly started putting hours in to practice more and I think I am making progress. I started from zero and I am now able to lift my front wheel but only a very short distance and sometimes looping out.
I am also doing wheelie a bit to aid my learning to get used to balancing but still rubbish and very inconsistent. Sometimes very short and sometimes maybe a couple of meters. It is no where near a controlled wheelie. I am within that region which is a mix of everything, slamming the front wheel hard, looping out and good short ones in between. But I am happy with what I am now able to do at this stage and I think if I persevere I will finally learn to manual even a short one but in controlled manner. Maybe just a question of when:)
Posted : 11/09/2018 10:27 pm
Page 2 / 2
