Leaky brake, new ca...
[Closed] Leaky brake, new caliper or not worth it?
So the middle small persons rear brake caliper (SLX) appears to be leaking or so I assume as his 2nd new set of pads are shrieking like mad and doing nothing.
Is it worth just replacing the caliper itself or should I bite the bullet and just chuck a brand new pair on?
Doesn't need massive power as he's only 9 so any recommendations to a cheap set/supplier?
Posted : 22/10/2020 7:53 pm
Typical Shimano micro leak by the sounds of it
Chuck a brand new non Shimano brake on and then burn all Shimano brakes worldwide!!!!!
Look at Textro offerings as they are cheap, reliable and use mineral oil like Shimano's
Posted : 22/10/2020 8:11 pm
Clarks M2
Posted : 22/10/2020 11:34 pm
£12.99 gets you an MT200 caliper including pads, though you will have to remove the banjo, and swap to a compression fitting instead (and remove the disc, and give it a thorough scrub with washing up liquid and a toothbrush,no sense in chancing cross contamination)
Posted : 23/10/2020 7:36 am
Went with the Clarks, ordered last night off Amazon and fitted this afternoon. Son is well chuffed so will do me and no messing about bleeding stuff!
Posted : 23/10/2020 8:53 pm
For the lighter rider those Clark’s brakes are a no brainer. Not mental powerful but they just do what they need to.
I stuck some M4’s on my 14 year old nephews bike and he’s been really happy with them so far.
Posted : 24/10/2020 11:44 am
Are those Clarks M2 any good for a 95kg fattie mincing about on easy bridleways?
Posted : 13/12/2020 1:20 pm
M2 seems fine to me, however swap out the Clarks pads for if you ride in the rain.
Posted : 13/12/2020 3:12 pm
Yes. My daughter has some, and I've tried her bike. People will waffle about them being less powerful, and they are, slightly. We're not talking about doubling stopping distance - more like a few cm. I'd absolutely have them on a commuter or general bike, I'd have them over cable discs too.
Posted : 13/12/2020 3:19 pm
Thanks
Posted : 13/12/2020 3:27 pm
M2's on my wife's bike & clouts on our daughter's.
So far they have been fit & forget, so get my vote for anything other than proper DH use.
Posted : 13/12/2020 5:26 pm
