LBS couldn't f...
[Closed] LBS couldn't fit crown race..
As bencooper rightly points out, there is a correct tool or three for this job. A file is not one of them.
+1
Are those gouges out of the angled surface of the race or just dirty grease? looks seated properly. Will likely be absolutely fine. The made a right pigs ear of the job.
I like split races and now tend to make the finest cut I can through mine using a Dremel. FSA do it on some of their headsets and not others strangely.
Posted : 30/08/2013 10:15 am
As it seems to have been established that the workshop is full of monkeys, it's surely time to name and shame?
Posted : 30/08/2013 10:35 am
Nah - the race is on properly, they just made a right meal of it.
Posted : 30/08/2013 10:40 am
Yes, there are gouges on the angled surface, I cleaned away the grease and had a proper look. Not impressed at all. Will this affect performance or damage headset in any way?
Looks like he used the old adjustable spanner trick as there are gouges on the other side perfectly lined up.
Built this bike for my GF using my old Fury as a donor bike (whilst treating myself to a Trek Stache 8 8) ) so its unlikely to be ridden particularly hard.
Time to find a new LBS...
Posted : 30/08/2013 11:40 am
it should be ok as the race doesn't actually turn in relation to the bit of bearing it rests on.
I'd be embarassed if I bodged something like that at home. A shop should be ashamed.
Posted : 30/08/2013 11:44 am
name and shame the bike shop.
move on.
Posted : 30/08/2013 1:37 pm
Pound Lane Cycles - Epsom
Avoid them..
Posted : 30/08/2013 2:39 pm
I do hope they find this thread and explain.
Posted : 30/08/2013 2:41 pm
montarius - Member
Or time to do stuff like that yourself - it would have taken less time than it has to take and post the photographs.
Posted : 30/08/2013 2:42 pm
I wonder how long it will be till someone anonymously emails them a link?
Posted : 30/08/2013 2:43 pm
The main part of the work was fitting the headset which I didnt want to bodge. But yes, I will be doing things like this myself in the future.
Posted : 30/08/2013 2:45 pm
Looks like they've hammered it on with a screwdriver!
Re. filing forks.....sure you shouldn't do it but once I had to file down a 27.0 fork down to 26.4 in an emergency and it worked totally fine. Took forking hours though and I'm never doing it again!
Posted : 31/08/2013 7:28 am
Pound Lane? More like Poundland - and I'd even suggest a pound's overpriced for that standard of workmanship.
Posted : 31/08/2013 7:39 am
Like others I like to do what I can myself as then at least my bodge jobs are my own 😀 , but that's a hell of a cocked up bodge job there! 😮
Posted : 31/08/2013 11:41 am
 chip
After a couple of far from satisfactory repairs by halfords I now do all my own maintenance.
I also recently built a bike from scratch as to get a complete understanding of how everything works.
That way there is nothing I cannot repair and I tend to nip any potential problems in the bud rather than let them escalate to the point where I would have to take it in for repair.
after initially worry about every task ahead i found everything quite straight forward once you actually get the tools out and make a start, using only supplied component instructions and park tools online information was excellent for the times I could not make sense of said supplied instructions.
And on the couple of a occasions where I needed help or reassurance with anything this forum came up trumps.
the best advice regarding any maintenance is have patience and the right tool for the right job.
And if you are unsure of what you are doing a little reading will put you right as once you understand how something works and not that it just does if you do this makes emergency repairs when you are out and about easier,which could save you a long walk home.
Posted : 31/08/2013 12:28 pm
Montarius, how long is the steering tube anyway?
Also don't the bearing run against the crown race? So won't those gouges wreck the bearings?
Posted : 31/08/2013 1:09 pm
No - the bearings have their own races, which just sit on the crown race.
Posted : 31/08/2013 1:17 pm
just seen those pics absolute monkeys
Posted : 03/09/2013 11:32 am
Well GF took this out for a good ride round Swinley at the weekend and there was some play / adjustment required after the ride but everything seems to be ok.
Just hoping that play doesn't comeback after every ride..
Posted : 03/09/2013 3:52 pm
Page 3 / 3
