Laptop went off won...
[Closed] Laptop went off won't come back on!
After I downloaded a newer version of HTC Sync on my laptop I connected my phone to sync it with the pc, as I was doing that a friend called round and when I came back to my laptop it had turned itself off, I thought it was the battery but it was connected to the mains so I pressed the on/off button it made the usual noises as though it was about to start up then nothing the screen remained black throughout. Any ideas?
Posted : 05/01/2011 12:09 am
Have you unplugged the phone? It could be reading it as a drive on boot and getting confused. I had a machine that wouldn't start up if you'd left a USB key in
Posted : 05/01/2011 12:21 am
Yes I unplugged my phone and external hard drive also, made no difference.
Posted : 05/01/2011 12:25 am
Have you tried pulling the battery and or pressing any hidden reset button?
If yes and your not getting any 'bios' - then could be bad news.
Posted : 05/01/2011 12:28 am
Have you tried booting it in safe mode, shutting down and restarting?
Pull the mains & battery out, disconnect any devices, leave for 30 seconds or so. The plug it back in &try it again
Posted : 05/01/2011 12:31 am
That worked Thanks ๐Ÿ˜€
Posted : 05/01/2011 12:39 am
hold the power button down for about 10secs then try the power button again, this will have the same effect as messing about with the battery
Posted : 05/01/2011 12:42 am
It was the first thing I tried holding down the power button but that didn't work. It seems ok now fingers crossed.
Posted : 05/01/2011 12:52 am
