KS Lev Southpaw - s...
[Closed] KS Lev Southpaw - stopping it from spinning
[#7674446]
Got a new KS Lev Southpaw
Great lever but i know there is a problem with it moving
What are people using to stop it moving on the bar?
Posted : 26/02/2016 11:06 pm
I used an allen key to tighten the bolt on the lever, sorted it.
Posted : 26/02/2016 11:33 pm
just gone one this week. only fitted last night and used at hamsterley today. fantastic ergonomics and great build quality.
made a big difference to my riding. didn't move on the bars but if it did I'd probably put a rubber shim on the contact points for more grip.
Posted : 27/02/2016 12:20 am
Mines not moved at all, including through wge at afan last weekend which was virtually underwater.
It is a great lever, why can't all dropper post ones be designed so well ?
Posted : 27/02/2016 12:45 am
Mine spins, carbon bars by anychace? Put some carbon paste and it seems better but still moves a bit.
Posted : 27/02/2016 12:47 am
A bit of carbon paste should do the trick.
Posted : 27/02/2016 1:18 am
I use a little wrap of Gorilla Tape on the bars.
Excellent lever.
Posted : 27/02/2016 2:10 am
Yep mine has started doing that with a carbon bar. Bloody annoying. Will be putting some carbon paste on today to see how that goes. Might rough it up slightly with a bit of sandpaper first though just to give the lever something to bite to.
Posted : 27/02/2016 11:11 am
I adjusted mine by opening it up slightly with a mallet and bit of wood ( could use vice with soft jaws ), been fine since, think the form on the casting is slightly too small in diameter, so it only nips up on a small area.
Posted : 27/02/2016 1:13 pm
Carbon paste worked a treat BTW 🙂
Posted : 04/03/2016 7:23 pm
