On a KS Lev installation are people fitting the in line barrel adjuster ?
Google suggests some are some not ?
Thanks
Not
Never had a problem with cable stretch and if you set the remote up carefully you shouldn't ever have a problem.
Even if you do it's an easy job to take the cable out and move the end clasp a little.
+1
Didn't do it here and all seems well so far.. *touches wood*.
Many thanks
I installed it on mine but not had to use it, can't say it was much extra hassle though
I installed mine...why wouldn't you want to? In fairness, I've not needed to use it...but at least it's there if required.
I did and I've used it, possible due to mechanical incompetence with the intial isntall, but this is the equivalent to bleeding a reverb when it stops working. The LEV is ace in that respect, the only issues I've had with it were fixed by a twiddle one way or the other with the adjuster.
Not fitted and not needed yet.
Fitted mine on both bikes and used it very very occasionally.
fitted mine but will remove it when i replace the cable next time, looks ugly and not needed it
I didnt on mine
I did on mine. Just allows me to take up the slack so you get an instant response on the lever.
I also put a flexible section coming out of the lever to stop the housing bulging out to the front of the bike.
