I'm looking at a i900R seatpost but would like to convert it to non-remote, ie with the lever under the saddle. Anyone know if this is possible? Can't see anything obvious so thought I'd put it to the collective STW powers.
Post it to me and I will return a lever version. May not be the same post but will be a ksi900l seriously remote is way better than crotch grabbing
Having had experience of both I prefer the underseat version. I swop it between two bikes so this can be done in seconds and the lever version requires almost zero maintenance.
It should be a simple case of reverse engineering the remote kit. All you probably need to do is find someone who has upgraded to a remore and get the lever parts off of them. I assume
Tom KP
scroll down for the lever.
I will buy your remote of you, I have broken mine and am quite shocked at the price for a replacement remote lever.
Whilst we are on the subject - anyone know where I can get a remote kit for an i950?
i900's can't be swapped between the remote/non-remote without changing the entire head. i950's can be easily converted though.
Using a dropper post should be as easy as changing gear. Anyone who thinks an underseat lever is better than a remote isn't using one to its full potential. ๐
I'll swap my underseat lever for a remote with anyone quite happily. email addy in profile.
