Kore realm bearing ...
[Closed] Kore realm bearing removal!! How
3 Users
Usually I don’t need bearing pullers etc etc swap out bearings. There’s usually enough bits and bobs in my tool box to sort it.
That said, I cannot get any wheel bearings out of these kore realm wheels. No purchase there at all!!
Any successful advise welcome
Posted : 31/10/2021 9:00 am
Sounds like you need a blind puller like these?
Posted : 31/10/2021 9:22 am
They aren't blind pullers
Posted : 31/10/2021 10:23 am
They aren’t blind pullers
What's the difference? It's a puller that can remove blind bearings..
Posted : 31/10/2021 11:09 am
Blind bearing pullers use a slide hammer as your can't get to the back of the bearing, hence blind. These you use a drift to hit the back, so not blind
Posted : 31/10/2021 1:37 pm
Blind bearing pullers use a slide hammer as your can’t get to the back of the bearing, hence blind. These you use a drift to hit the back, so not blind
Fair enough.. partially sighted then?
Posted : 31/10/2021 2:29 pm
Posted : 31/10/2021 3:44 pm
