I want some 29er'ish steel forks to replace my 100mm suspension forks - they'll be used with a 26 inch wheel on the front-end of my 1992 SS Kona tho' ...
Yeah, ok, I know how it sounds, but my forks currently come in with an A to C measurement of 465mm (even with my [albeit skinny] arse sat on the bike), so a set of the 29er Kona P2's (at ~460mm) would [i]appear[/i] to be ideal, but there doesn't seem to be any stock anywhere on the surface of the Earth, and I can't seem to find out when there will be ...
So, are there any alternatives worth a look d'ya think?
There's the Surly KM forks I guess, but after that I'm out of ideas.
Givens are that I need QR dropouts, disk tabs (I'm using a n M4 with a 200mm rotor for comedy value), and be made of steel.
I don't believe in carbon, it's just not natural.
Singular do some with the hummingbird. Not sure if they're available seperately though.
Charlie the Bikemonger does some lovely looking Niner ones (470A/C). Gert pricey tho!!
salsa
A few people have been sticking a 29 wheel in a 26 fork...
Depending on offer - I may sell my 29er GT Peace steel forks.
470mm axle to crown and about 185mm steerer.
Disc only.
Just read back your posting....
The measurement of 465mm will be without any sag. ie. No rider weight on the bike.
For sure a 1992 Kona will NOT be suspension corrected for a rigid fork of 470mm long.
If you take into account some suspension sag - it sounds like to me maximum length of rigid fork you should be looking at is about 400mm.
I have a raw finished steel fork (400mm~410mm) - it will need some paint. Vee only.
Let me know if you're interested.
or lookout for a pair of surly 1x1 forks.
Wouldn't you need 475mm forks for 29'er?
460mm (which I sold on the classifieds) is 100mm suspension corrected.
Ideally, I guess you could get away if it has tyre clearance.
