KMC quick link / SR...
[Closed] KMC quick link / SRAM power link - change when changing chain?
7 Users
Just a quick tech question. When changing a chain (due to wear and not mechanical failure) should I also replace the power /quick link, or are these things good to go for a few thousand miles?
Posted : 10/04/2015 3:12 pm
SRAM 10sp are supposed to be 1 use only (although its never stopped me reusing them).KMC are multiple use
Posted : 10/04/2015 3:14 pm
new chain, new link.
Agreed, they're already the weakest part of the chain, if you've decided your chain's worn I'd want a new link too!
Posted : 10/04/2015 3:18 pm
Cheers all, will order a couple more with the chain.
Posted : 10/04/2015 3:19 pm
Yep.
When new things will be within a tolerance.
When worn it will be worn together [out of tolerance from new]
Reusing one will give you a part that is not of the correct dimensions and is therefore more likely to fail.
Posted : 10/04/2015 3:20 pm
You know you get one with the chain?
Given how a chain wears I'm not convinced that's that much of an issue - it's not like the plates physically stretch.
Posted : 10/04/2015 3:22 pm
@ njee
I usually run Shimano chains which come with that crap pin instead of a missing link.
Posted : 10/04/2015 3:25 pm
Aside from an inability to remove the chain (for whatever reason) I prefer pins!
Posted : 10/04/2015 3:29 pm
I have used my current SRAM Powerlock link for three summers, on 4 different chains, and take it on and off at least once a month to clean the chain.
Posted : 10/04/2015 4:34 pm
You're totally going to die
Posted : 10/04/2015 7:15 pm
I always use a new link with a new chain but strip out the old ones from worn chains to use as spares. i think my bitsa bike has a chain with about 4 in, they seem to last longer than normal links!
Posted : 10/04/2015 7:47 pm
