Just fitted the one...
[Closed] Just fitted the one up 42 tooth cog
[#6039040]
It looks well made, and went on easy enough.
It was a bit of a faff setting the B tension correctly, it shifts perfectly with the clutch on the mech disabled, but I had to reduce the tension on the clutch to get it to shift properly with the clutch engaged, which I guess somewhat defeats the point of a clutch mech.
Anyway will see how it goes, but it saved just under a pound in weight off the bike.
Posted : 15/03/2014 9:41 am
What rear mech and cage length are you using? I'm interested to try this myself, running SLX rear mechs on both bikes, one long cage one medium. I imagine the long cage one will work fine at least.
Posted : 15/03/2014 9:47 am
This is with a shimano XT shadow+ long cage mech.
Posted : 15/03/2014 10:18 am
 fbk
I've been running one for the last few weeks with a medium cage XT mech. Very happy so far - smoother shifting than I expected.
B-tension is screwed all the way in and it just about clears.
Posted : 15/03/2014 10:23 am
I am using a Zee short cage mech with a home made 40t, it shifts great,
http://www.pinkbike.com/video/351634/
Posted : 15/03/2014 11:23 am
Which gear do you get rid of on the cassette when you fit these?
Posted : 15/03/2014 11:27 am
You get rid if the 17tooth gear
Posted : 15/03/2014 12:51 pm
Haven't tested mine enough to shout about it yet but it's very impressive so far. I've a sneaking suspicion I've picked up a weird spacing issue in teh cassette where the 17t was though, it shifts lovely on and off the OneUp but there's a slow shift in the middle of the block. More examination needed.
Oh, I had to replace the b-screw on my XT medium cage mech. But I think the Ragley mechhanger just naturally needs a lot of b-screw, it was already wound out almost all the way. You can fit it from the inside but far easier just to fit a longer one.
Posted : 15/03/2014 2:50 pm
Mines in a box ready to go on the new build.
I've pulled at 16t off an 11-32 xt cassette for my DH bike to span that spacing gap.
Posted : 15/03/2014 4:35 pm
I prefer the general lee cassette, you get 3 more cogs for £30 more. Dpacing through the gears is better and you dont lose your 17
Posted : 15/03/2014 5:04 pm
