just blead my brake...
[Closed] just blead my brakes
just blead my juicy three rear brake...and the fluid i got out of it is black....is this normal?
Posted : 24/01/2010 1:10 pm
no.
flush it all out.
Sounds like a seal may have dissolved?
Posted : 24/01/2010 1:16 pm
How long has it been in there? You get a mix of wear particles in the fluid - alloy dust from the cylinders, bits of seal and so on. It does discolour with age as well I think
If the brake works fine just ignore it.
Posted : 24/01/2010 1:17 pm
break seems ok...no leaks or anything...just didnt expect the stuff that came out to be sooo uber black...
oh actually one of the pistons doesnt move much?
Posted : 24/01/2010 1:23 pm
Did you bleed right thru until clean fluid came Out? I would do that.
As for the sticky piston - it could be related in that that seal might be disintegrating.
Posted : 24/01/2010 1:49 pm
ah ok...i blead them all the way through...they feel pretty solid now...i think ill just run it till it dies...which could be years...
Posted : 24/01/2010 3:29 pm
