Juicy 3 reach adjus...
[Closed] Juicy 3 reach adjustment?
[#1573605]
Looking at buying some Juicy 3's for the wifes bike, but can't see any mention of reach adjustment on product descriptions. As the wife has small hands, I really need to get her brakes with reach adjustment.
Are there any Juicy 3 owners that can advise please.
Cheers.
Posted : 04/05/2010 7:53 pm
you adjust the reach with an allen key inside the lever, really easy to do!
Posted : 04/05/2010 7:56 pm
Thanks renton. That's good news - no probs with allen key job, 'cos hopefully it'll be a one off adjustment.
Posted : 05/05/2010 12:02 pm
The problem with the juicy 3s if im right is that while you can adjust reack, theyve got quite a long freestroke, so if you wind them in too far you might hit the bars before you get full power.
I really like them as brakes but the freestroke is annoying.
Posted : 05/05/2010 12:32 pm
Free stroke on these can be reduced by a strip/clean/silicone greasing of the caliper pistons and seals, and obviously bleeding afterwards.I've done this many times, and ended up with old brakes that feel far better than a fully bled brand new set, I guess they don't grease them during assembly and the dragging seals keep retracting the pistons more than is necessary.
Posted : 05/05/2010 12:43 pm
Cheers for the advice. Sounds like they're quite serviceable then(?). Do they have a 2 piece 'split-able' caliper like the original Hope Minis? ('cos they were a doddle to strip and service).
Posted : 05/05/2010 12:50 pm
yes you can split them no problem
Posted : 05/05/2010 1:04 pm
as sweepy said, some sets of juicys (of all numbers) end up biting quite close to the bars as it is. But a well bled set of juicys (get a bleed kit where you can de-gas the fluid helps a lot) is nice and bitey. I had a set of 5's from merlin which were like that straight out of the packet, and mrs julian's as came fitted on her specialized myka fsr are also great.
Failing that I have found the older style shimano's (565, 765, lx, m800) are both inexpensive, easy to bleed (you don't even need a bleed kit, just a tube and do them like you would a car) and easy to get a nice 'quick' bite and short lever throw on. Only downside being that you can't get seals to service a duff set, you just spend £30 on a new capplier or lever and replace the whole unit. Not that they go wrong much.
Posted : 05/05/2010 2:15 pm
Cheers for the beta on the Shimanos - like the sound of the easy bleeding. If I do end up with the Juicy 3's, I guess I'm gonna have to shell out for a proper Avid bleed kit at some point, as I've just bought a bike with Elixirs on it. (Elixirs are great at the mo, but just thinking of when I come to renewing fluid in them)
Posted : 05/05/2010 2:26 pm
You won't get away with bleeding your elixirs without a bleed kit to securely fit in the bleed ports (never tried any of the cheaper ebay versions). The other day I went from my 203mm m800 saint to do a downhill run on my mate's bike with elixir cr's on 203mm and lordy, the difference was 'arresting' !! 😆
Posted : 05/05/2010 3:04 pm
