joystick maxx2 user...
[Closed] joystick maxx2 user question
hi just recently got a joystick maxx2 and went to use it earlier and it wouldnt turn on right i figured it needed a charge. so charged up and it wouldnt come on properly full wasnt on med was low and lowest setting wouldnt work either.
i then stuck in charger again and it worked but when switching between levels from high to med then low does it flash off then light up again then fade slightly when you drop to the lower levels ?
just want to check its now working right rather than having to send back to check
cheers (oh and is low really crap ?)
Posted : 24/10/2009 8:27 pm
I have no idea what you're on about, chief.
All I have to say is that "low" on USE lights is really low. Basically a "be seen on road bits" setting.
Posted : 24/10/2009 8:33 pm
sorry lol when im on full then flick to med it flashes off comes back on bright then fades slightly and stays on and does the same on the low too just wondering if its meant to as my old joystick just clicked onto the lower light level . if that makes more sense
Posted : 24/10/2009 8:37 pm
Mine doesn't do that
Posted : 24/10/2009 8:47 pm
Hang on though mine might be a Maxx not a Maxx2
Posted : 24/10/2009 8:48 pm
just wondering if ive got a dudd ;-(
Maybe - mine just clicks between light settings, no fading
Posted : 24/10/2009 8:51 pm
Sounds like a dud mate, mine double click to start, click once for med again for low and hold for 1 sec to flash.
Anything else is just wrong!!
Posted : 24/10/2009 8:56 pm
yeah i do that to swap modes but it goes off when i click for a split second the quickly comes on bright and then fades slightly . hard to describe really lol does yours flash off between modes heathy ?
Posted : 24/10/2009 8:59 pm
Yep, flashes off for a split sec between modes, there is a very small amount of fade when switching between med and low, almost as if its setting itself. No fade however when switching to full power.
I'm blind now BTW!!!!
Posted : 24/10/2009 9:10 pm
ah mine might be right then . just never noticed before on my old joystick.
i got it direct from them as an upgrade and it was all bench tested before sending to me . but not sure what was going on today with it not turning on. maybe the battery was low or something seems to be fine now so long as the fade thing is ok.
and the low really is shite lol and thanks for looking for me mate your a star
Posted : 24/10/2009 9:12 pm
No probs, still blind though!! LOL
Posted : 24/10/2009 9:18 pm
