XT 9 speed.
Only on bottom gear, which gets used an awful lot these days.
Very little B screw adjustment left.
It's been on for a while (years), has it just worn out?
Still seems to index perfectly and it's clean and lubed.
Posted : 26/09/2017 11:23 am
Bent hanger?
Posted : 26/09/2017 11:26 am
Hanger seems spot on, will get it checked though.
Posted : 26/09/2017 11:28 am
I had that on mine, in my case it was as the hanger was v soft and the b screw had worn a hole into the hanger(so the b screw was effectively shortening). I fixed it by getting a tiny flat bit of hard metal (shim) and putting that between the b screw and the hanger.
Posted : 26/09/2017 12:58 pm
I had that on mine, in my case it was as the hanger was v soft and the b screw had worn a hole into the hanger(so the b screw was effectively shortening). I fixed it by getting a tiny flat bit of metal (shim) and putting that between the b screw and the hanger.
...or remove the B screw and screw it back in from the wrong side ๐
Posted : 26/09/2017 12:59 pm
I tried that(several times....) and it is a LOT harder than it sounds......... ๐
Posted : 26/09/2017 1:03 pm
Shim probably less hassle than effing about with screwing the wrong end.
Posted : 26/09/2017 1:04 pm
I tried that and it is a LOT harder than it sounds
Did you try using the [url= https://www.parktool.com/product/shop-hammer-hmr-4 ]specific tool[/url] for the job?
very nearly .......................
Posted : 26/09/2017 1:07 pm
