Jeez, what a dull q...
[Closed] Jeez, what a dull question - Which Ant+ cadence/speed sensor?
I have a Bryton GPS that has a HRM/Cadence function. I bought it from the classifieds along with a Decathlon/B'Twin cadence/speed sensor, but I'm buggered if I can get the two to pair up and, anyway, the B'Twin sensor is not what you might call 'elegant'.
So, which one should I replace it with?
Posted : 01/05/2015 4:15 pm
The new Garmin Cadence/Speed sensor http://www.wiggle.co.uk/garmin-speed-cadence-sensor/ is quite neat. Uses internal accelerometer rather than the older style magnet / sensor setup.
I've got this setup on my Roadie.
Posted : 01/05/2015 4:21 pm
Hmm, being super-picky, the o-ring type attachment on the crankarm isn't the most aesthetically pleasing.
Posted : 01/05/2015 4:37 pm
[i]Hmm, being super-picky, the o-ring type attachment on the crankarm isn't the most aesthetically pleasing.[/i]
I don't think you need to use this as I think this is just to give you an easy option if swapping between bikes.
If its anything like the [url= http://www.wiggle.co.uk/wahoo-rpm-cadence-sensor-bluetooth-40-and-ant/ ]wahoo one[/url] I use this has a sticky pad to stick to the back of the crank but it also comes with a rubber mount and xip tie.
The wahoo one is very good but mine is cadence only - a speed sensor isn't necessary.
I approve of your super pickiness ntw ๐Ÿ™‚
Posted : 01/05/2015 4:46 pm
What do you pair that with Gary? I have the sensor for the turbo but only have my phone to use outside. Prefer not to mount the phone on the bars so was looking for recommendations.
Posted : 01/05/2015 5:48 pm
Garmin accelerometer mount is o-ring only. I like the ease of moving between bikes. The speed sensor is excellent for bikes on a turbo.
If you want magnetic sensors, I also like the Bontrager speed and cadence. The magnet slips over the crank before attaching the pedal. Looks very smart.
Of course, you could always take the classic STW option - buy a new frame with integrated sensors. My Giants have these and they are great. Trek also has built-in options. Not the cheapest option though ๐Ÿ˜‰
Posted : 01/05/2015 7:24 pm
My wahoo sensor is paired with a garmin 500
Posted : 02/05/2015 7:43 am
For a cadence sensor with a magnet, you can get a tiny magnet and put it inside the pedal spindle. Its neater than attaching it around the crank.
Posted : 02/05/2015 11:55 am
