but there's no 'spare' guides to route it on my Mojo.
Any suggestions on how I should do it, are the stick one guides any good? Do I want to be sticking stuff to my frame? Are there piggyback guides that can attached to the existing ones?
Pictures and suggestions would be great.
cable tie to your existing cables?
That's the plan but I though there might be something else.
I used the M-Part stick on one,s have been very good.
Don't Ibis do bolt on guides for the top tube, or is that just for the HD?
i just zip tied mine, but i dont really care about my aesthetics :p
The seat tube flared guide busts easily and need careful secure alignment ( watch the bending of the to gland on the seat post collar) . TF Tuned do spare ones.
On my Canyon the u bolt clamps under top tube need careful angling too so IMO its worth get right. bits. Seem en CRC or web somewhere (vague & not entirely helpfulI know).
A friend of mine has a mojo with no reverb tabs. He is running 1x10 so we very carefully drilled out the cable guides for the front derailleur to remove the little stop where the outer butts up to and then ran the hose through there. Had to take the barb off so it was just hose as its a very tight fit when threading through but it worked and no problems thus far. No picture I'm afraid as its in his basement!
Your Reverb should've come with piggy-back guides
I used the Jag-wire stick on guides on my Yeti. Seem to work fine. They are stuck to the helicopter taped areas rather than the frame itself so I don't know if that helps.
ditch the front mech, go single ring, hey presto! Spare cable guides, and less faff on your bike*
*probably not.
It's one of the OEM ones from On One so it came in a bag with the post, remote and one zip tie / guide.
I'm planning on a 1x10 setup eventually but I'm sorting the bike out for a mince in the Alps next week.
Nothing wrong with using cable ties.
Just think about where you are placing them and there is no reason you can't make it a nice neat job
As honourablegeorge said, m-part stick on guides, used them on a variety of bikes and never come unstuck etc, have them here although I got from CRC I think [url= http://www.tartybikes.co.uk/rim_brake_spares/mpart_stickon_cable_guides/c5p10896.html ]http://www.tartybikes.co.uk/rim_brake_spares/mpart_stickon_cable_guides/c5p10896.html[/url]
In that case, you can buy them on eBay for pennies
Zip-tie and a washer.
Can't find a pic to illustrate what I mean, but loop a cable tie round the hose, put both ends through a small washer, then round a frame tube.
That make sense? neat and works well.
New frame?
New frame?
There's a thought, I quite fancy a HD.
Sounds good I'll try that. I was thinking 2 zip ties looped together, but your suggestions sounds better.
Expect a 'What titanium washer thread' immanently.
I recommend nylon washers, stop anything scratching etc and they deform a bit so it works even better. Lighter too ๐
Thanks IA.
Mine was a simple and cheap solution-if you are happy bleeding your parts.
Take the rear brake hose off and run a length of black heat shrink over that is wide enough to put the Reverb hose through too.
Put the Reverb hose through, re-attach bleed the Reverb and brake and it looks pretty clean as you now have a single line from front to rear.
To finish it put one cable tie around the seatclamp to hold the Reverb hose tight and turn the seat 360 degrees. The hose then coils around the post and when the seat extends up and down the slack cable doesn't catch the tyre/suspension.
