I've been a bi...
[Closed] I've been a bit daft, I think. Any tips?
After I replaced the frequently coming undone rear axle in my superstar rear hub with a steel equivalent, I thought I'd put some thread locker on it to stop it coming undone. Now I can't undo it. It is one of those ones where the non driveside end cap screws on. Basically, have I cocked up by using loctite on a steel thread? Is this a known no-no?
Also, any tips for loosening it? One of my riding buddies has suggested heating it with a hairdryer to melt the loctite a bit. Haven't tried this yet, but does anyone else have any ideas?
Obviously it is still in the wheel, through the hub. The freehub needs a bit of attention as I need to service it.
Thanks.
Posted : 12/10/2017 6:16 pm
Use some more leverage.
Posted : 12/10/2017 6:18 pm
Hairdryer or boiling water aka get it hot.
Posted : 12/10/2017 6:20 pm
[url= http://henkeladhesivesna.com/blog/how-to-remove-red-threadlocker/ ]Heat[/url] is the right way
Posted : 12/10/2017 6:21 pm
What grade?
Yeah heat generally works. Used it before. Try boiling water if hairdryer isn't enough.
Posted : 12/10/2017 6:28 pm
Boiling water.
Posted : 12/10/2017 6:29 pm
I remember having to use a blowtorch to drift out kingpins on a Hillman Imp. That works, if you're not interested in re-using any of the parts!
Posted : 12/10/2017 7:40 pm
check the grade before applying heat - some get stronger with heat
Posted : 12/10/2017 8:37 pm
Blue 243 I think.
I'll have a proper look when I get the chance.
Posted : 12/10/2017 10:02 pm
Yeeeeeeeessssss.
Shifted the bastard with mole grips.
Adjustable spinner one side, mole grips the other. The two tools of the mechanically incompetent working in perfect harmony.
Posted : 14/10/2017 3:13 pm
Imminent 'where to get spares for Superstar rear hub axle assembly damaged during servicing' thread... ๐Ÿ™‚
Posted : 14/10/2017 6:57 pm
boblo - Member
POSTED 6 MINUTES AGO # REPORT-POST
More than likely, yes. ๐Ÿ™‚
Posted : 14/10/2017 7:04 pm
