ISCG - can i drill ...
[Closed] ISCG - can i drill new holes to make it fit ISCG 05
Got a new frame coming with 05 mount, can i drill new holes in my ISCG stinger to make it fit?
Posted : 04/01/2011 10:06 pm
Is it really worth it (drilling, tapping - invalidating warranty?) over the cost of buying a new Stinger?
[url= http://www.e13components.com/iscg_explained.html ]http://www.e13components.com/iscg_explained.html[/url]
Posted : 04/01/2011 10:21 pm
He wants to drill the hole in the stinger no?
cant see why not if they are far enough apart from the old holes
Posted : 04/01/2011 10:26 pm
It can be done. But its a bit of a pain and the final result isnt great. You can drill the holes to fit ISCG05 fine, but because they need to be countersunk you end up removing most of the material between your drilled holes and the original ISCG holes/slots. I did it to my old SRS and used it for a while with no issues, but i woudn't say it is an ideal solution. I will try and find a photo, that might explain it better.
Posted : 04/01/2011 10:27 pm
 DeeW
I think he's on about drilling the Stinger not drilling and tapping the frame.
You may well be able to drill new holes, depending on if there's enough metal on the backplate: ISCG05 are further out from the BB than ISCGold I think. Difficulty is probably going to be 'countersinking' the bolt holes so the bolts don't foul that stupid granny ring of yours: there's not a lot of clearance in there.
BTW Did you know all the cool kids are going 1x10! It's the future: it said so in Dirt.
Posted : 04/01/2011 10:34 pm
 DeeW
beaten to it..
Posted : 04/01/2011 10:35 pm
Ok, found a picture. Now i've looked at it again it actually looks worse than i remember, there really isnt much left between the holes. May not have been my smartest move. 🙄
Posted : 04/01/2011 10:44 pm
Well considering the original 'holes' are actually slots id not worry about the thin bit between your new holes and the existing slots, as long as you dont want to go back to ISCG that is.
Posted : 04/01/2011 10:58 pm
The stingers seem to still sell for a decent amount 2nd hand, at least 50% so I'd sell it and get a new one, might only cost £10 which I reckon is good to remove the faff and potential disaster of drilling.
Posted : 04/01/2011 10:59 pm
Doh! Misread the OP's post - sorry!
Posted : 04/01/2011 11:01 pm
