IS to post adapter ...
[Closed] IS to post adapter issues: WTF?
Just tried again to fit my new XT775s.
You know the ones; from Ribble for much cheapness of money, with 160mm adaptors.
It shouldn't be rocket science, should it? 160mm adaptors for 160mm discs; 185mm adaptors for... Oh, you've guessed it.
Well... the 160mm adaptors don't let the calipers clear the rotors, and the new 185mm Avid front adaptor (for the 185mm Avid rotor) doesn't clear it either. We're not talking a couple of mm here either, there's CHUNK of space between the caliper and the adaptor if you don't want it to foul the rotor.
So, WTF is up? Have I missed something vital?
Posted : 09/08/2010 12:12 pm
2 possibilities to try...
1. Youve got the adaptors on upside down.
2. Your trying to use the wrong adaptors (they are front and rear specific)
3. You bought the wrong ones?
Posted : 09/08/2010 12:27 pm
All 3 of what Stato said.
Avid brakes do use those washers from V-brake pads to space them out though, so if it's not a big gap you can just use them (although you shouldn't have to- I run XT calipers and Avid adaptors and rotors without them)
Posted : 09/08/2010 12:29 pm
Aren't the calipers front and rear specific as well? Not sure how to tell the difference though...
Posted : 09/08/2010 12:31 pm
The Avid CPS system (washers) is built into the Avid calipers not the adaptors, you can use Hayes/Hope/Shimano/Formula/Avid adaptors and they should all work the same (note: some brands are not cross compatible as they are designed for different sized calipers so might have intereference)
Posted : 09/08/2010 12:32 pm
Stato:
1 Can you imagine anyone being that stupid? ๐Ÿ˜‰
2 Nope.
3 Again, nope...
Seriously though, the rear adaptor seems to have actually been fitted to the caliper the wrong way round, which didn't help... The front mount was my own fault.
Thanks mate.
Posted : 09/08/2010 12:38 pm
