Is this head-tube c...
[Closed] Is this head-tube crack fatal ?
Hi, Orange E6 from 2001, Easton 7005 ally tubing. Used now for commuting and mild xc. Is this fatal, can / should / how be repair considered ? I bow to the wisdom and thank in advance.
[IMG] [/IMG][/URL]
Posted : 30/03/2015 10:04 am
jubilee clip.
Posted : 30/03/2015 10:05 am
Unfortunately also found this ….
[IMG] [/IMG][/URL]
I'm loathe to scrap the thing, I love it and it's original in 90% (bought second hand).
Could / should I seek a welder ??
Ta again
Posted : 30/03/2015 10:08 am
You need to get the OD of the tube measured accurately if it is a common metric size I would remove the forks drill a small hole in the end of the crack to stop it continuing up the head tube and find a clamp to fit over the outside of the tube. A jubilee clip or proper type band clamp would be better than nothing but I think the most important point is to drill the end of the crack to stop it getting longer.
Just seen the pic of the second crack and I reckon the frame is probably scrap from a financial point of view, I am sure it can be welded if you really love the thing that much.
Posted : 30/03/2015 10:10 am
Cheers both. I haven't taken to fork out yet to check the inside of the tube. Scraping a fingernail over it, it seems superficial, but yes, I think a couple of small holes and a dollop of weld stuff is the minimum.
Posted : 30/03/2015 10:12 am
 tomd
It looks pretty terminal for the frame. If you look on ebay or the classified quite a few really nice older alloy frames go for very little money. Could be easier option that repair, and just swap the bits over.
Posted : 30/03/2015 10:13 am
How good is your dentist? You're looking at this all wrong, what you have right there is a bullet proof excuse for a new bike. repeat. NEW BIKE.
Posted : 30/03/2015 10:18 am
yes it is repairable. Frank the Welder has a frame of mine at the moment. He is replacing the whole headtube. The trick is the aging of the aluminium after the work to put the strength back in. I am restoring the bike to its 90's bling and wanted it repaired 'properly'.. its costing an arm and a leg but not a kidney.
As to the if it is financially viable, thats only a question you can answer and depends on how much you love the frame. Only you know the answer.
A cheaper option is to get it welded by a decent welder, allegedly many of these prolong the life of the frame and work quite well. The weld will be obvious and how much trust you have in it will be down to you and the type of riding you do.
EDIT: agree with some of the above comments, dont think its a rare frame you have there, eBay might offer you the same model pretty cheaply and might be the best answer.
😯 You sure?
One word which does not spring to mind whilst looking at that second image is 'Superficial'.
I would not be riding that
Everything is repairable but that is a fairly substantial head tube crack at both ends that will only get worse
You could drill it and reduce the bike to pootling duties but i would not be wanting to nail gap jumps on that bike [ or any other actually but you get the point]
Posted : 30/03/2015 10:21 am
Okay, here's the bike in all it's "glory". It's tatty as a tatty thing having been stored outside for years in Hong Kong humidity. As it's not used for anything too boisterous, I'm thinking, tack it up and carry on sailor ..??
[IMG] [/IMG][/URL]
Posted : 30/03/2015 10:23 am
 hora
Thats done. Completely terminal. Hang it in the shed. Dont sell it as spares or repair.
Posted : 30/03/2015 10:24 am
Posted : 30/03/2015 10:27 am
Bung it on the classifieds.
ti-pin-man … left the UK a long time ago, who/where is Frank the Welder.. New head tube ? Hmmm, that's a thought .. I really appreciate all your replies. I've plenty of bikes to ride, but am strangely fond of this old jalopy ..
Posted : 30/03/2015 10:28 am
Do not ride it as it is. Just don't! The stress of riding was enough to break the metal that was there, what do you think it's going to do to the void which is now in its place?
It's a super light race bike from 14 years ago, these things don't last forever. Just move on.
Posted : 30/03/2015 10:31 am
Jambo beat me too it, 2 x jubilee clips and it's job done!
or
Send frame back to Orange for warranty repair as a chancer! 🙂
Posted : 30/03/2015 10:32 am
 poah
my orange was the same - I junked it
Posted : 30/03/2015 10:36 am
Aluminium Frame+Steel Headset Cups+Serious Humidty = ****ed.
It's definitely time to retire the old girl.
Posted : 30/03/2015 10:37 am
There's a lack of optimism on this thread - suggest zip-ties top and bottom and confine riding to XC or light AM, but not Enduro.
 hora
Strong parcel tape?
Posted : 30/03/2015 10:39 am
Really, thanks everyone for replies. I'll yank the fork out when I get a chance, and if if it is any way salvageable, I will do so. As mentioned, it's little more than a commuter these days, but I do like it .. ah well, as someone mentioned, new bike time is a-coming .. Cheers,
JKM
I mean, what's the worst that could happen? Has anyone ever seen a headtube burst? It'd probably just get really bad bearing-knock, like an amazingly loose headset....
Posted : 30/03/2015 10:40 am
The fact that it's failed so dramatically without apparent trauma suggests the Aluminium is past it's best, so even if you were to replace the headtube, the rest of the frame could easily follow suit.
The jubilee clip idea could work though (if you're unhealthily attached to the frame)... you could even lay a carbon wrap over the jubilee clips to distribute loads and improve aesthetics, though you'd risk transferring stresses elsewhere
Posted : 30/03/2015 10:43 am
Yeah, but he can just use a few more jubilee clips. He's not using it for #enduro. Just mild XC...
Posted : 30/03/2015 10:45 am
Based on the location of the cracks I wonder if the headset was slightly out of tolerance (or headtube).
Oh and bin it
Posted : 30/03/2015 10:48 am
Anybody got any pics of a similar type bodge ? I'd like to keep riding this for reasons that most here will understand .. I like it … it's quick and comfy, although not as bullet-proof as I thought !!
In the meantime, I'm going to take the fork out and take it to the local (this is HK !) window frame maker to see if he can drill and tack the thing ..
Pics shall of course follow …
Thank You all very much
Posted : 30/03/2015 10:53 am
Make it some wall art.
Posted : 30/03/2015 10:58 am
At a guess corrosion between the headtube and the headset cup has built up and split the head tube top and bottom.
The bottom cup gets the majority of the forces through it so its pretty weakened. Given the top has gone as well its not safe to ride really.
I had a Marin which I'd ridden offroad twice before being converted into my commuting bike developed the crack in the top of the headtube right in the centre. Never noticed until I stopped commuting and went the refurb the bike and the top cup basically fell out. Ooops!
It shall remain in the garage roof as a trophy.
Posted : 30/03/2015 11:09 am
Is it just me that is amused by the use of the word 'found' - suggesting that that monstrous crack only came to light during a thorough inspection of the bicycle.
Posted : 30/03/2015 11:22 am
Body filler > Rattle can > ebay 😉
bigyinn if you were the original owner Marin's had a life time warranty on all their frames. If you take it to a Marin dealer I've seen very old stuff replaced with new in the past without any problem.
Posted : 30/03/2015 11:23 am
Yeah but you can't. It's over.
Plenty of other good frames around.
Posted : 30/03/2015 11:36 am
 kcal
Hardest part is facing the decision to say "good bye".
I'm looking at finally ditching my 1998 M2, maybe in a couple of years I'll actually get around to taking the action!!
Posted : 30/03/2015 11:49 am
Surely Duck tape is the answer!!
Posted : 30/03/2015 11:53 am
[s]Surely Duck tape is the answer[/s]!!
Two jubilee clips, top and bottom ...sorted
Posted : 30/03/2015 11:56 am
Having once owned a Land Rover I would also be loathe to scrap that frame as it CAN be repaired. However the bearing seats will have stretched a tiny bit and will never be the same again, no matter how good the repair. Any maybe that's a warning that something else is about to let go?
Posted : 30/03/2015 12:18 pm
[url= https://farm6.staticflickr.com/5034/14198593710_494887a582_q.jp g" target="_blank">https://farm6.staticflickr.com/5034/14198593710_494887a582_q.jp g"/> [/img][/url]
This is the new headtube on my frame. It was split nearly as bad as yours, he removed the old broken one and put a new one on.
Frank The Welder here: [url= http://www.frankthewelder.com/ ]http://www.frankthewelder.com/[/url]
If you are seriously attached to the frame, send it to him, it might not be worth it financially but it can be done if its the love of your life.
Posted : 30/03/2015 12:21 pm
That is some set of welds 😯 🙂
Posted : 30/03/2015 12:23 pm
 hora
Even if you never rode if off road again, falling at even 10mph onto the tarmac can hurt.
Posted : 30/03/2015 12:26 pm
Tried a sticker on it ?
Posted : 30/03/2015 12:30 pm
You're not a proper Orange fanboi if you haven't sent a worthless frame halfway across the world to have it repaired by a legend of the business.
Posted : 30/03/2015 12:41 pm
I was pretty serious about the repair! 🙂 I want to ride it, like proper ride it, not just pootle.
Posted : 30/03/2015 12:44 pm
Ha, I've got one of those E6s (well have passed it on to the girlfriend for a commuter now as it's a bit small for me).
Had it from new - bought from Mountain Trax back in the day. Only changed the forks to a set of exotic carbon rigids. Everything else just keeps on going.
Don't think I've seen any others about (apart from this one now).
Posted : 30/03/2015 1:16 pm
I had a headtube replaced on a frame as well, a friend gets frames manufactured so he just stuck my frame in the hold when he was going over to Taiwan and asked the factory's prototypers to do it while he was in a meeting. The cut the old head tube off, welded a new one on, put in the alightment table to straighten everything out, heat treated it, and aligned. By now the clear coat was totally fubar so it was sandblasted then joined the production like of a bunch or Birdy frames and was powder coated in Reise and Muller grey (lucky escape as the batches of frames before and after were being painted to look like new york chequer cabs). After powder coating it was re-aligned again. No small amount of work and given what I'd bought the frame for and it having no market value at all in any condition it wouldn't have been worth doing
All done as a freebie which was nice, but it was no small amount of work and given what I'd bought the frame for and it having no market value at all in any condition, it wouldn't have been worth paying to have it done.
After all that the frame was good as new, but striped and repainted and without its original decals and the like its just a frame, not my old bike reborn - 'just' a usable frame, not special in anyway other than it being a good fit for my gangly lanky bod. I still use it as a hack in fact (1999 frame repaired in 2006 I think)
But if a frames charm is its originality then it won't seem very original after all that - finding an old frame that matches the components you have would result is something more authentic
I have to say the welds on mine aren't so conspicuous, that said, in all likelihood it was getting repaired in the factory that built.
Posted : 30/03/2015 1:30 pm
FTW can indeed remove the lacquer (and did this) get polished and re-lacquer if needed. Decals are relatively straight forward to replace and as its a piece of mtb design history I pulled the trigger and shipped it over. He repaired some chainsuck marks too. Looks nice, just have to be patient waiting for it.
Nice to get it done by the same factory and I wish mine was free, haha.
Posted : 30/03/2015 1:42 pm
If it needs to be ridden enduro then grip fill first, duck tape and then the clips.
What could possibly go wrong?
Posted : 30/03/2015 1:55 pm
This is what happens if you only use one jubilee clip 😉
Posted : 30/03/2015 2:08 pm
My mate used to have an E3. All the welds looked like that.
Posted : 30/03/2015 2:35 pm
Just lob it in that canal and be done with it.
We won't tell anyone.
Posted : 30/03/2015 2:44 pm
OP's in HK, it'll have to be the harbour!
Great excuse for a new ride 🙂
Posted : 30/03/2015 2:52 pm
Drill holes at the base of the cracks and get a local fabricator to weld it all up. You'll get a few more years of commuting out of it at least.
Posted : 30/03/2015 3:14 pm
The bit I love is that after posting the little crack and picture initially, you followed it up with "also found this" and a picture of the san andreas fault, located about 2 inches away from the other, smaller crack.
As above, financially it's for the bin, you just need to work out what the intangible value is and go with that. I've kept one of my frames going for ages past the point where it stopped making sense in monetary terms, because I love it.
For now, I reckon you'd have to be properly mad to ride it. If nothing else, it'll probably make the cracks work but generally I don't like my forks exiting through the front of the bike
Posted : 30/03/2015 3:31 pm
Sodajim - Member
The cracked frame was a discounted replacement for a steel Pine Mtn that had a crack behind the headtube due to a hefty frontal impact at some time. I got a replacement for the cracked frame at the cost of £125 which actually worked out out very well as I wanted a disc hardtail frame and most of the bits to upgrade it were already in the shed. WIN!
Posted : 30/03/2015 6:23 pm
Thnx All. Northwind, the sequence was due to lack of computer skills! I've taken on board your comments, bike will be put on gardening leave for a while, until I get some time. All input appreciated. Won't bore you all with a what CX bike for commuting ... scuttles off to view the Tripster thread
Posted : 31/03/2015 12:13 am
a manitou FS is worth repairing.
a generic aluminium orange frame that was made in Taiwan? Viking funeral and new frame time.
Posted : 31/03/2015 1:12 am
 jruk
Are you sure it's a crack and not a sticker?
Posted : 31/03/2015 9:03 am
Update, of sorts for those interested. Slipped the fork out, and the inside of the tube is fine. Minor corrosion on the headset, steerer of the fork, all within expectations for a bike of its age. Wet'n'dry on the cracks, not as horrendous as I'd feared.
On advice/warnings/sympathy/scorn all gratefully taken on board, I rode (yes !) to the local aluminum window frame maker, who has promised to drill a couple of small pilot holes (oo-err missus) and tack the thing up. For a couple of quid, I am happy to take a chance. It'll be relegated to shopping and pub duties, but shall be loved in its dotage.
Once again, thanks for taking time, I'll stick a pic up when it's done.
Jon
Posted : 31/03/2015 10:37 am
