Is there such a thi...
[Closed] Is there such a thing as a 28 or 30t middle ring?
Rich
Posted : 20/05/2013 9:59 pm
There's a few 30T ones around. Do a search on the XX1 rings. Used for 1x10 generally.
Posted : 20/05/2013 10:02 pm
28 or 30t singlespeed ring, maybe (only one I know of smaller than 104mm BCD is a 30, and that uses an offset ring).
28 or 30 t middle, no.
Posted : 20/05/2013 10:07 pm
Shimano are doing a 20-30-40 Deore chainset for 29ers in2014 aren't they?
Posted : 20/05/2013 10:09 pm
There's a few shops that will machine up any ring you want, search for betd goldtec
Posted : 20/05/2013 10:14 pm
I run a 27T ring.
It's the smaller of the two Middleburn Duo rings.
Not sure that helps though?
Posted : 20/05/2013 10:21 pm
Op you are limited by the bolt hole dimensions. 32t doesnt leave much tooth above my Shimano crank arm's spider.
If you wanted smaller i would have thought a trials crank and a custom ring but that would possibly need to be 1x
Posted : 20/05/2013 10:24 pm
Thanks fellas. I will man up instead.
Posted : 22/05/2013 8:22 am
If you fit a non-offset 30t 104mm ring like the Extralite one you have to file your spider so the chain doesn't hit it. Don't think anyone does one with ramps etc, begs the question though... why not just change down?
I was thinking that, sure they are.
Posted : 22/05/2013 9:03 am
