Is there only one m...
[Closed] Is there only one model of RS Revelation 2019
Obviously forgetting about travel, offset etc. Seen them described as RC or Charger etc. Do all 2019 Revs have the same crown, stancions, damper, innards etc whether OEM or after market?
After specifically 150, 29er, Boost, 51 offset
Posted : 26/05/2019 11:18 am
Aftermarket ( uk distributor) only have rc s listed which is motion control damper, charger maybe oe, wanted a set of charger with 42 offset but couldn’t get them so ended up with pike ultimates ( which was more than I wanted to spend, but they are silver too 😉 )
Posted : 26/05/2019 11:50 am
There is two versions - RC and Charger RC. Totally different dampers, otherwise the same fork.
Rev Charger RC is now Pike Select for 2020 (And gets the ultimate axle as the QR option)
Posted : 26/05/2019 11:56 am
Thanks. Ben - so, I just need to make sure it’s Charger RC? Will the serial number inputted into the SRAM website confirm this?
Posted : 26/05/2019 12:57 pm
Charger RC forks have a dial on the damper side that looks more like a charger dial (the one off the Pike RC I think), and says charger on it... Not sure if the serial will confirm spec but quite probably.
Posted : 26/05/2019 1:02 pm
Cheers.
Posted : 26/05/2019 1:30 pm
Just double checked zyro trade site ( wanted to double check I hadn’t bought pikes when could have got the revs in spec wanted 😉 ) & no selects listed are the select/charger rc just oe then Ben?! Or is just zyro aren’t stocking them as it’s too much cross over between charger equipped pikes & revs
Posted : 27/05/2019 3:16 pm
