Is there an adapter...
[Closed] Is there an adapter to use a 20mm axle fork with 15mm hub and axle?
Or should I find some 15mm lowers?
Thanks
Posted : 09/04/2017 8:15 am
You'd need a custom axle I think. Are the hubs definitely not convertible? If not its still probably cheaper to swap hubs
Posted : 09/04/2017 8:18 am
Assumed the hub wasn't convertible...might have to double check! Novatec D541SB....
Thanks
Posted : 09/04/2017 8:23 am
Can sell you a cheap flow ex rim on DT Swiss 350 20 mm hub if you're interested.
Posted : 09/04/2017 8:34 am
These should do it,they're a push fit.
[url= http://www.superstarcomponents.com/en/electro-front-adaptor.htm ]Other brands are available[/url]
Posted : 09/04/2017 8:36 am
I used similar on my Crests,when I changed forks from 20mm to 15mm.
Posted : 09/04/2017 8:39 am
Those are specific to the hubs.
Posted : 09/04/2017 8:41 am
Sorry,it's Sunday morning,you're right al,you may find that that they use an adapter for 15mm as Google says they sell them in 20mm ,15mm and QR.in which case removing the adapter may well do it, as the default is usually 20mm.
Posted : 09/04/2017 8:51 am
Thanks all. I think I might have found some Novatec adapters (should have checked first).
Thanks
Posted : 09/04/2017 8:53 am
And ali-express sell a 20mm end cap.
Posted : 09/04/2017 9:18 am
This the one you found thejesmonddingo?
http://s.aliexpress.com/zyIbYbIR
Posted : 09/04/2017 9:20 am
 poah
Sorted! Thanks all. Novatec EU selling them for £12 delivered. Cheaper than new lowers or new hub.
Thanks all
Posted : 09/04/2017 10:06 am
