Whereas I'm perfectly happy to make a recommendation based on my own experience, but I'm not so committed that I must prove to everyone I'm right by taking such extreme measures.😉
Its not about proving I am right 😉 Its about wanting to save folk money in chain wear and expensive ineffective lubes. Its about trying to help my fellow mtbers 😉
You and I have been on this forum for a very long time TJ. Your personality type has always been to prove you're right.
It doesn't matter the topic, for you, it's point of principle. Why do you think you get into so many arguments?
We're really not talking big money here anyway, although, I appreciate you are Scottish😁
"What sort of crazy wax has a melting point higher than 100c?"
Not Putoline, the manufacturer gives the MP as 68c, flashpoint 200c. I think TJ is overdoing it a bit if his is boiling off water. Though I suppose if you've not dried your chain properly it's one way of doing it.
'I appreciate you are Scottish'
He's not you know....
I use gearbox oil. Clings well and runs relatively clean.
£6/ l
Muc Off Dry Ceramic most of the time then Purple Extreme if it looks like it's going to be really wet.
Both seem to clean off well using a bit of that Fenwicks Foaming chain cleaner.
hmm i replied to this ages ago.
Anyway squirt. all year round. stick it on when you get home and jobs a good un.
Might have to try W&S based on all the above.
I do have muc-off wet and it does have it's place. It's for the sort of ride that is wet from the start, not sandy at all and involves a lot of water crossings.
The Plutoline sounds like a good idea but I have a couple of questions . 1 how long does it last and 2 I presume that you have to remove the chain every time you apply it .
Bookmarked
Ramsey - some folk have not found the benefits I have - see science officer above
IME it lasts 100+ dirty mtb miles and 1000 wet road miles
Yes you take the chain off, dunk it in the tin of molten wax, stir it a few times, then hang it over the tine while the excess drops off. refit chain, run it thru a rag a few times to make sure there is no excess ( cos it stains stuff badly)
After a couple of rides the outside of the chain will look dry - but inside the rollers the wax is still there lubing the chain. Again IME chain life is hugely extended compared to bicycle lubs and cassette wear greatly reduced and its nice to have a well lubed chain the whole time
The stuff stinks and stains badly if you get it on clothes and is a bit off a faff but for me the fact you do not have to do it very often and the greatly increased chain life make up for it
Winter road miles, depending on how crappy the conditions are, I was getting about 700 miles.
Is the putoline like a pre made parafin wax, parafin oil and xyline thinners type affair?
I guess so - but with more additives and no solvents
