And if so, what do I need to order and from where?
Similarly, for the left hand side, I also looking for a method to mount both XT brakes and One Up dropper lever on a single clamp.
(I'm not up-to-speed on all the I-Spec variations)
Ta
Edit the add: it's a GX Eagle 12 speed mechanical shifter (not AXS or Transmission) if that matters
Posted : 15/05/2025 8:46 pm
Posted : 15/05/2025 9:23 pm
vlad_the_invader reacted
Wolftooth do something similar as wellย
https://www.merlincycles.com/wolf-tooth-shiftmount-172503.html
Several different variants, check which one you need!
Posted : 15/05/2025 9:34 pm
... but you can get it really cheap via AliExpress as I did recently for the exact same combo.
You will need to figure out which i-spec it is though.
Posted : 16/05/2025 5:32 am
Turns out LBS had some OneUp adaptors in stock and on sale, so 👍
Posted : 16/05/2025 7:12 am
