Is there a reliable...
[Closed] Is there a reliable way to stop disc brake squeal in the wet ?
Tried a number of things over the years to no avail. Just wondered if anyone had found a fettling technique that reduced squeal caused by water ? I suspect the answer is no from experience .
( awaits the jokers)
thanks in advance
Bill
Posted : 14/09/2017 11:58 am
Road brakes? Toe in really helps.
Posted : 14/09/2017 12:02 pm
toeing in disc brakes?
Posted : 14/09/2017 12:05 pm
People ride in the wet ?
Posted : 14/09/2017 12:08 pm
Staying indoors?
It's not really a big problem though is it?
I'd rather have noisy but effective brakes TBH...
Use the brakes. Once they get hot/dry they stop squealing
Posted : 14/09/2017 12:12 pm
Decent pads? If shimano, the cheap official Shimano organic ones are hard to beat at £7 a set.
Posted : 14/09/2017 12:13 pm
3 in 1?
Posted : 14/09/2017 12:25 pm
it is a massive problem if you're riding anywhere where you might meet up with a horse - you really don't want to be squealing to a stop - and possibly spooking the horse, which could then throw its rider.
in that respect discs were a big downgrade from my lovely magura hs33s...
Posted : 14/09/2017 12:29 pm
Don't brake?
Posted : 14/09/2017 1:05 pm
Use them harder for less. The heat soon dry's out any moisture.
I did see some weird anti brake squeal device fitted to a Trek at a show once. Comprised of some metal and rubber thing that was supposed to cancel out vibrations causing noise.
Posted : 14/09/2017 1:15 pm
I can't add much, other than to say that my brakes don't squeal in the wet. They make a bit of a grindy noise, but no squealing.
Maybe change brakes/discs/pads to see if you can eliminate.
Posted : 14/09/2017 4:59 pm
The BB7s on my commuter HOOOOOOOOOOOOOOOOOWL in the wet. I suspect it might be the pads, cos I've never had it before.
Posted : 14/09/2017 5:04 pm
For a quick fix this is worth a try. Douse the disc and caliper in washing up liquid then ride dragging the brakes for a couple of minutes, rinse and repeat if necessary.
Posted : 14/09/2017 5:16 pm
Is Copper Slip supposed to help here? I bought some but never fitted it (to the back of pads, I believe..)
Posted : 14/09/2017 6:00 pm
What discs, and what pads? Some will just howl, no matter what.
Posted : 14/09/2017 6:06 pm
The second most effective thing I did was buy the most skeletal rotor I could, a Magura Storm SL, on the premise that there would be less surface area for the water to sit on, reducing the 'skin' of water forming between pad and disc.
The most effective thing I did was remove the SRAM Level brakes from my Superfly, burn them, throw the remains over a rainbow, and fit some TRP Spyres. Still squeel a little but not so badly that they make paint run and passing priests to cross themselves...
Posted : 14/09/2017 8:06 pm
