That's not just a bunch of Shims and isn't rubbish?
Thanks
you can get a full king ISO boost conversion kit, but it's bloomin expensive.
https://avt.bike/products/chris-king-conversion-upgrade-kit
I've just got a 6mm spacer with shrink-wrap holding it on on the brake side and a 6mm plate under the disc.
Been working great like that for at least 5 years.
I did look at the King kit but they're taking the piss at that price.
Isn't that their USP? 🙂
you can get a full king ISO boost conversion kit, but it’s bloomin expensive.
It will not allow for converting from non boost to boost.
That’s for changing your freehub/converting to through axle on a boost or non boost hub I think. Not between boost and non Boost
$344/£281
Plus of course your initial outlay for the wheels/hubs
Flog them off and buy a set of DT/Superstar/Hope/Other.
Nope, it’s never possible without doing daft stuff, don’t even think boostinators work for ck hubs.
For two years I've had a spacer on both sides of a rear hub and a spacer under the disk on a non king hub.
It's been fine. I'm sure it would be fine for a king hub.
Last time I looked you couldn’t do it and I couldn’t find any kits. Saved me a fortune as I just kept the old bike rather than upgrade.
Is a boostinator there equivalent for a rear 135 qr / fun bolts ? If so where I can I get it?
I’ve had a spacer on both sides of a rear hub and a spacer under the disk on a non king hub.
this is what I’m doing on a front king hub. Not ridden it yet but can’t see why it wouldn’t work?
Thought I’d replied to this but can’t see it now. I ran a generic boost adapter kit on on my CK wheels without issue. Only a pain if you frequent swap wheels about or are prone to punctures.
