Is the Macic 717 ri...
[Closed] Is the Macic 717 rim the same as the ZTR Flow
 Gunz
As above really, I've always had the 717 but have seen a flow deal that saves me a bit. Are they comparable for weight intended use (bit of 24 hour racing, trail centres, nothing to huck'tastic or racey)?
If anyone has seen a good Hope hub based deal I'd also be very interested.
Many thanks.
Posted : 03/09/2013 1:37 pm
Simple answer: no.
Flow is heavier and heavier duty than a 717. If you're after a Stans rim you want a Crest or, at a pinch, an Arch EX
Posted : 03/09/2013 2:02 pm
