Is running Hope X2 ...
[Closed] Is running Hope X2 caliper with XTR M970 rotors possible?
7 Users
Question in title?
Posted : 03/11/2010 7:52 pm
Yes
Posted : 03/11/2010 7:59 pm
and another yes
i run my X2 on formula 203 rotors
and they`re the best brakes ive had so far
only issue is i wish they came as standard with a softer pad compound
Posted : 03/11/2010 8:39 pm
Good Question, are there any other compatable with Shimano eg. Avid?
Posted : 03/11/2010 9:10 pm
You can use any disc with any rotor
Posted : 03/11/2010 9:18 pm
Yes and I do, in the 160mm flavour.
Posted : 03/11/2010 9:25 pm
There you go I never knew that...Ta
Posted : 04/11/2010 12:46 pm
I tried Tech V2s on Shimano rotors and because the pads were deeper than the braking surface on the rotor I got loads of fork twang each time one of the spider arms passed through the caliper and it felt terrible so I'd check that first.
Posted : 04/11/2010 12:50 pm
X2's are very different to v2's; the v2 has a huge contactpatch, and as such should only be used with v2 rotors. The x2 has a far more conventional size pad contact area, and works fine in the above combo.
Posted : 04/11/2010 1:28 pm
cynic-al - Member
Although BB7 calipers and XTR M970 disks mean you might have to trim a bit off the pad.
Posted : 04/11/2010 4:48 pm
Thanks
Posted : 05/11/2010 10:04 am
