is my seatpost wier...
[Closed] is my seatpost wierd or my saddle?
5 Users
I have one of these:
http://www.planetx.co.uk/i/q/SPPXCARBH/planet-x-black-head-carbon-seat-post
my saddle is a specialized toupe and the angle of the rails is such that I can't get it level, the seatpost clamp will just not give me enough rotation, my previous saddle had more angled rails and I had no problem getting it level
do I need a new seatpost?
Posted : 14/09/2014 6:29 pm
 Spin
Have you tried turning the cradle round?
Posted : 14/09/2014 6:38 pm
the two bolts are different, one threads into the seatpost from the top down, the other threads into a cylindrical piece from the bottom up, which sits in a slot, no way to turn it around
Posted : 14/09/2014 6:46 pm
The top down bolt is for fine adjustment. Tighten up the bottom-up to clamp he saddle and adjust the front bolt. Some posts have a knurnled wheel on the front bolt.
Posted : 14/09/2014 7:04 pm
yeah I've got a front knurled bolt with a hex in the middle, good thing the saddle has a cutout to expose the hex because I wouldn't be able to turn it with my fingers - way too tight
no matter what I do the saddle is nose up unless I leave the main bolt at the rear too loose to ride on
Posted : 14/09/2014 7:28 pm
What bike?
Posted : 14/09/2014 7:57 pm
planet x xls
Posted : 14/09/2014 8:01 pm
I've got the same post but no cutout in my saddle. The way I set mine was to adjust the front bolt using my fingers with the back bolt loose then tighten the back to the correct torque. It took a few attempts the get the angle right but it wasn't too difficult in the end.
Posted : 14/09/2014 9:02 pm
I have tried this and the top plate needs to bend in order for the back of it to make contact with the rails, I torqued the back bolt to about 2 newtons and tested the front and it was clicking straight away at 6, so I'm a bit scared to go full 4 newtons at the back, I feel like either the front bolt will strip / shear or the top plate will crack
Posted : 14/09/2014 9:17 pm
In fairness I have no idea how tight my front bolt is as I can't get a torque wrench to it. I know it hasn't snapped though...yet...
Posted : 14/09/2014 9:26 pm
