IS mount brakes on ...
[Closed] IS mount brakes on Post Mount forks - how does it work then?
I have some IS mount 160 mm Hope mono mini brakes, and need new forks, but the Sids I want only come in Post Mount. I know I can get adaptors etc, but do I need to change the rotor size or caliper to make things fit?
Ta muchly
Posted : 18/07/2010 6:03 pm
I could be proven wrong on this but as far as i know when you use an IS to post mount adaptor you need to go up 20mm in disc size. So it means you're going to need a 180mm disc as opposed to your old 160mm. Which i might add might pleasantly surprise you in the increased stopping power.
Posted : 18/07/2010 6:17 pm
