Is it possible to c...
[Closed] Is it possible to convert a rear XTR hub to 130mm?
As above. Is it just a question of removing a spacer or with the axle being threaded, a complete axle swap with Ultegra or Dura Ace to gt from 135mm to 130mm?
Posted : 28/08/2009 2:24 pm
You can either change the non drive spacer for a 5mm shorter one and then chop the axle down 5mm as well or get a road axle kit, oh and re check the dish on the wheel.
Posted : 28/08/2009 3:12 pm
