Is ebiking "giving ...
Is ebiking "giving in/up"?
Lifting an e-bike above your head is hardly like pressing a 20 or even 30Kg barbell.
Some very odd and frankly stupid reasoning in this thread.
Ultimately, irrespective of views (mine included), if you ride a bike then all is good.
What does it matter what sort of bike it is, or how fit the rider is.
Getting out, having fun and doing something shouldn't be labelled anything, other than good 🙂
Posted : 25/12/2023 9:18 pm
Marko, StuE, StuE and 1 people reacted
 Aidy
I even struggle carrying normal bikes over rocky terrain for any kind of distance.
Posted : 25/12/2023 9:40 pm
All my bikes are kept up 104 stairs. The ebike is a lot harder to do.  There is no doubt they are much heavier and harder to lift.  One of their big drawbacks along with the noise and limited range
Posted : 25/12/2023 9:44 pm
kelvin and kelvin reacted
I’m well aware what lifting a bike entails. I’ve lifted quite a few. I just find it amusing how lifting an eBike is somehow seen as massively different despite being a little bit heavier than some steel bikes. This whole thread is just amusing
Imy ebike is 14kg more than my steel mtb or over twice the weight
Posted : 25/12/2023 9:46 pm
Well, the elephant in the room is the ethical concerns and environmental damage caused by the mining and production of the lithium for the batteries (and the near slave labour in some places) for what is, effectively, a rich (white?) man's toy. Exploding batteries have also caused some deaths and burnt down quite a few houses (so much so that certain cities are considering banning ebikes).
Obviously, the more expensive, ethically sourced lithium that reputable bike brands use are exempt from these concerns....
Some of you may not be concerned about such issues, others maybe are.
Merry Christmas 😉
Posted : 25/12/2023 10:03 pm
mtbqwerty and mtbqwerty reacted
Stupid question, caveat with being a non ebiker or even haven ridden one.
Once the battery packs in can you just pedal it like a non electrically assisted bike?
I assume the drag from the motor or weight of the bike makes this unrealistic?
Posted : 25/12/2023 10:05 pm
riklegge and riklegge reacted
Yes
Nope, rides like a heavy bike, not noticed drag when I've tried
Posted : 25/12/2023 10:13 pm
inbred853 and inbred853 reacted
“ Once the battery packs in can you just pedal it like a non electrically assisted bike?
I assume the drag from the motor or weight of the bike makes this unrealistic?”
I’ve done this a lot because on quite a lot of my group rides I’m more towards the faster end of the group when we’re all on normal bikes - so if I turn up on my ebike I turn the power off with the group and just use it for the solo bits before and after the group ride (because I cycle to/from the start from home rather than driving).
So on a normal bike with a middling speed group I’m at the front uphill and stopping and waiting fairly often. On my turned off ebike I’m nearer the back of the group but not holding anyone up.
The extra drag is tiny on my Levo - much less than the extra drag from running dual ply downhill vs trail tyres. The extra weight is annoying from a standstill and you use lower gears and/or stand up more but it’s not that bad - I’m sure most of you have ridden with mates who are 1.5 stone heavier than you and they’ve survived!
This is also why I don’t think “range anxiety” should really be a thing - if you run out of power you just have to pedal harder, it’s not like you get stranded at the side of the road.
And it’s much less bad than trying to ride home on a flat tyre, without or even with inserts!
Posted : 25/12/2023 10:15 pm
weeksy, inbred853, inbred853 and 1 people reacted
not must use without knowing actual weight of either one. Less than 30kg and it’s not really much of an issue. Could go around all evening in circles here. Not productive but could be mildly amusing I guess
Posted : 25/12/2023 10:21 pm
Cheers all, I thought that might the case but wasn't 100% sure.
Posted : 25/12/2023 10:22 pm
unwilling to even consider you might be wrong
My irony meter just exploded.
Posted : 25/12/2023 10:26 pm
crossed, kayak23, crossed and 1 people reacted
TJ - Dogbone.  Do you drive to ride?  I don’t .  Driving to ride is the real planet killer
I drive to less than 5% of my rides. Does that count as don’t? (I could lie for internet points). But go to any trail center and the e-bikes have driven there as well.
Posted : 25/12/2023 11:23 pm
My sister in law's ebike is only about 1.5kg heavier than my non-e Nukeproof Reactor!
Posted : 25/12/2023 11:52 pm
Just for the record, lifting a big unweildy lump of a 25kg ebike onto your shoulder and climbing over a stile is absolutely nothing like lifting a small 25kg weight over your head in a static environment. Nothing at all. It's doable, but not bloody easy
Posted : 25/12/2023 11:53 pm
Marko, CheesybeanZ, twonks and 7 people reacted
Dogbone " let he who is without sin cast the first stone"
Posted : 26/12/2023 12:35 am
Yep, I am very glad my bike weighs 5.8kg when it comes to stiles. I have 3 to go over on one of my routes and wet slippery wood and a heavy bike getting over some awkward stiles is not a great combination I imagine.
Posted : 26/12/2023 8:49 am
Because they’re trying to stay fit (and reduce their impact on ‘our’ NHS), something that e-bikers pretty much by definition have indeed given up on.
You're letting your emotions and that huge chip on your shoulder get the better of you.
By definition, loads of ebikers have done quite the opposite to what you say they're doing. They're cycling now, which they often wouldn't have done otherwise.
Cyclists are not a monolith. Making simplistic and sweeping statements is puerile, at best. Trying a bit of nuance and tolerance instead.
Making binary, divisive and narrow minded statements like yours is absurd too. It's entirely possible to enjoy both ebikes and conventional bikes equally, on different days. The rider remains the same person.
Posted : 26/12/2023 10:16 am
ngnm, thols2, flyingpotatoes and 15 people reacted
I think twonks hit the nail on the head at the top of this page…
Getting out, having fun and doing something shouldn’t be labelled anything, other than good 🙂
If you want to ride an e-bike then ride an e-bike, if you want to ride a non e-bike then ride a non e-bike, it really doesn’t matter, just ride what you can or what you have if it makes you happy.
Posted : 26/12/2023 10:37 am
Marko, twonks, StuE and 3 people reacted
"Well, the elephant in the room is the ethical concerns and environmental damage caused by the mining and production of the lithium for the batteries (and the near slave labour in some places) for what is, effectively, a rich (white?) man’s toy. Exploding batteries have also caused some deaths and burnt down quite a few houses (so much so that certain cities are considering banning ebikes)."
The ethical issues of ebiking are interesting you can point the finger but you also have lithium batteries in cars, phones, computers and any number of common items so why single out ebikes for comment.
The main hope for ebikes is that they will be used by people to reduce the number of car journeys the do. EVs won't save the planet on their own cycling if it's on bikes or ebikes might make a difference.
Mountain biking where you drive somewhere to ride or fly somewhere to ride is not very helpful.
I still use a car to drive somewhere to cycle or sea kayak but my car use is a lot less than it used to be.
We chose to live in an urban area so we could have a short commute by bicycle and sometimes go somewhere nicer to do visit the outdoors. Most of my cycling is now from my doorstep unless we go on holiday.
Posted : 26/12/2023 11:14 am
funkmasterp, Marko, Marko and 1 people reacted
Thanks for that, as you say some stupid reasoning on here - I am unfortunately in a place/age where lifting a normal bike over my head is awkward, so along with the price this has put me off getting a motor.  Now with these threads there is often a misunderstanding that just because one person has good reasons not to make a purchase, it is taken as a blanket condemnation of everybody who has made that choice.  As so often it is the relationship between objects that is important and I dont think a motorised bike is a good fit for me.  Of course it will be a good fit for many others and that's fine.  If my thing was downhills, my priorities would be different and I may raid the emaciated piggy bank.  I cannot begin to think of how they must have changed cycling for those living somewhere like most of Southern France.
I cannot begin to say how much I hate locked gates.
Posted : 26/12/2023 11:29 am
I’ve read the news stories about the fires caused by e-bikes causing deaths but I’ve never seen a thing suggesting any cities considering banning e-bikes, which cities are they?
Posted : 26/12/2023 11:43 am
By definition, loads of ebikers have done quite the opposite to what you say they’re doing. They’re cycling now, which they often wouldn’t have done otherwise.
How many, what %? Many people riding eBikes were previously riding bikes were they not? How many, god knows.
Posted : 26/12/2023 11:55 am
“I am unfortunately in a place/age where lifting a normal bike over my head is awkward”
Obviously I don’t know your personal situation but if it’s possible for you to get better at lifting a normal bike over your head, then it’s a very good thing for overall health. Lifting and carrying moderately heavy awkward loads helps reduce the chance of injuries that plague older people, which happen more to people with less good balance, core strength, overall strength, mobility, etc.
Posted : 26/12/2023 12:19 pm
Really not so.  lifting awkward shaped stuff is high risk of injury at all ages.  25kg above shoulder height is a high risk activity
Posted : 26/12/2023 12:23 pm
“Really not so. lifting awkward shaped stuff is high risk of injury at all ages. 25kg above shoulder height is a high risk activity”
Please read properly. I didn’t say e-bikes, I said normal bikes!
Lifting and carrying heavy e-bikes is not easy for unfit people but if you consider MTBing an athletic pursuit (which is the main argument of many against e-bikes - that they reduce your fitness) you should be able to lift and carry an ebike.
And if you ride normal MTBs for fitness then you should aim to be able to lift and carry a normal bike. If you can’t then unless you have serious dysfunction it’s a good fitness goal.
I agree that lifting and carrying an ebike is a LOT harder than carrying a normal bike - but you can’t argue against ebikes due to them causing MTBers to become lazy and unfit but also claim they’re too heavy to lift over gates.
Posted : 26/12/2023 12:51 pm
The main hope for ebikes is that they will be used by people to reduce the number of car journeys the do. EVs won’t save the planet on their own cycling if it’s on bikes or ebikes might make a difference.
I don't know anyone who's actually "replaced" their car with an e-Bike, I know people who have used them for a couple of regular local journeys (escorting kids to school, run to the shop, etc) which they could easily have done previously on a non-assisted bike (sort of making them the less environmentally friendly option?).
While I'm sure people exist who've gone all in on living the life and fully ditched the car for an E-cargo bike, such people/families are the exception not the rule still and (I assume) have lifestyles and finances that accommodate the choice.
I just don't buy the 'car replacement' theory for eebs, it's mostly bollocks, people generally buy them in addition to a car not instead of one. Car journey replacement? Maybe, but again weather and circumstances probably conspire to make it the less preferable option half the time...
E-Bikes are mostly toys, which is fine, but let's not pretend they're going to save the planet, they really won't.
Posted : 26/12/2023 12:56 pm
funkmasterp, StuE, StuE and 1 people reacted
cheif - I used to train people in safe moving and handling of loads- even 12 kg above your head is high risk activity.  Add in an awkward shape and its even higher - and this is nothing to do with fitness - its about the limitations of your muscular skeletal system.
Okish if you lift weights and have built up your body to do so.  Fitness does not equal increased ligament and tendon strength
These are the safe limits for loads:
https://www.architectureanddesign.com.au/getmedia/00e585f9-4a54-47ed-801a-73bb012bc525/Image1_10.aspx
Posted : 26/12/2023 1:16 pm
“ These are the safe limits for loads:”
Feeble loads
These are completely ridiculous. If you can’t handle more load than that, how are you going to be able to catch yourself if you trip, how are you going to be able to get out of a chair or bed when you’re 80+, how safe are you going to be if you have a bike crash?!
I have three different awkward loads I regularly lift and/or carry in the shape of 4, 8 and 10 year children. Even the small 4 year old girl can lift 10kg off the floor which is more than half her body weight.
Posted : 26/12/2023 2:08 pm
Sure, some of them were. Not sure you realise that I was replying to the suggestion that ebiker have given up and are costing the NHS as "they hace given up on staying fit" which is a ridiculous statement. Even cyclists moving to ebikes don't necessarily stroll exercising. In fact some of them may have stopped cycling all together.
Posted : 26/12/2023 3:34 pm
All totally different scenarios.  I suggest you take your expertise to the HSE and inform them that they are wrong.  I CAN lift 50 kgs.  Its not SAFE for me to do so
Posted : 26/12/2023 3:40 pm
“ I suggest you take your expertise to the HSE and inform them that they are wrong.”
I know they’re wrong, as does anyone with a reasonable amount of knowledge of how the human body responds to loads over time. If they were right, and if the NHS’s approach to back pain was right, then we wouldn’t have ever-increasing problems such as bad backs.
Avoiding load is not the answer. Building in life habits that increase mobility and strength is, and if you ride MTBs then an easy challenge is to get comfortable with lifting and carrying your own bike.
Posted : 26/12/2023 3:50 pm
So what is your expertise that you can say that these limits created by experts in the field are wrong?
Posted : 26/12/2023 4:04 pm
The problem is the "injuries that plague older people".  They have arrived.
Summing up where this thread is going
Posted : 26/12/2023 4:10 pm
Not sure why they've even bothered to differentiate between the sexes in those charts when they've utterly failed to differentiate between fitness disability strength and illness levels, what utterly useless charts.
Posted : 26/12/2023 4:11 pm
I do love an armchair expert.  "anyone with a reasonable amount of knowledge of how the human body responds to loads over time."  You mean the very people who created this safe load guidance?  Its clear you have no actual knowledge of the physiology or anatomy.  Fitness does not increase the strength of your connective tissue.  ~Strength training does a little but not much.
So you think you know better than people who study this stuff for year and are experts in the field.  Very good.
Posted : 26/12/2023 4:16 pm
Was amusing up at Afan today, I was on the MTB and the lad was on the ebike. Well, sort of, he had it switched off on most of the climbs and trails and got back having 5/5 bars left lol. Nutter. But it does show for the earlier question posted, you can ride it fine without power, it won't shock anyone to know, he was quicker uphill with power off than I was on the Fuel ex
We saw and chatted to 7 blokes in total, all middle aged/50s, all we're on ebikes. We only saw 1 person on a MTB which was a youngster who'd got it for Xmas present.
Posted : 26/12/2023 4:25 pm
“ Fitness does not increase the strength of your connective tissue. ~Strength training does a little but not much.”
You can’t say “fitness” and not include strength training.
There’s a total lack of joined up thinking in modern medicine regarding biomechanics but that’s a problem that affects almost everything in the modern world. Lots of experts doing very specific analysis but rarely going enough steps along the path to create a real solution. Anything hurts, stop doing anything. Children getting killed by cars, keep the children inside. Cyclists dying on the road, make them wear helmets. Crime increasing, put more people in prison.
However I’ve been here long enough to know that you are a man of very fixed opinion, so I’ll stop there.
Posted : 26/12/2023 4:30 pm
safe load = 25 * 1 / age
Posted : 26/12/2023 4:35 pm
ON this one I actually have fairly high level expertise - I used to train folk who trained folk in safe movement of loads.  I also understand the A&P involved and how these safe limits were reached
Fitness and strength are not the same thing at all.  Thats very basic physiology.
So what is your expertise that means you can say that this well researched and valid limits are wrong?
Posted : 26/12/2023 4:36 pm
I ride a 100 miles a week road but pretty much exclusively use my e-bike off road now. I went up a local Corbett yesterday and would have gone for a run rather than grind up a hill if I didn’t have the e-bike. Guess that makes me one of those giving up? IMG_3864
Posted : 26/12/2023 4:42 pm
fettlin, Marko, fettlin and 1 people reacted
 LAT
Outlive by Peter Attia is a well regarded book on this subject.
their recommendations are for an average person, not for someone who  trains for strength and mobility. a sure fire way to protect yourself from injury from lifting things is to train your body to be able to lift heavier things safely. it is also good for reducing the loss of strength and mobility as you age, which leads to injury and illness.
sorry for going off topic, anyway, e-bikes, they are too expensive for me to be able to afford one, so i’ve no idea if they are giving up.
Posted : 26/12/2023 4:48 pm
TJ the limits in that diagramme are self evidently bollocks for a huge percentage of the population.
Quite simply because the population is so different.
Posted : 26/12/2023 5:13 pm
 mc
Any manual handling course I've done in the past 10+ years has given no maximum or recommended maximum weights. Instead it's been a case of only lifting what you feel comfortable lifting, as 10kg for some people is too much, whereas others will quite comfortably lift 10kg with a finger or two.
Posted : 26/12/2023 8:22 pm
 mboy
10 pages of people asserting their opinions as fact, refusing to acknowledge that other peoples opinions might be equally as valid... 10 whole pages!
I'd say this was peak STW, but I'm pretty sure this is a new low...
jameso made this comment back on page 2 of this thread...
Like it or not in time MTB will be a powered sport for the majority and riding off-road on a standard MTB is a future niche.
Those of us that work in the industry and are aware of purchasing trends know that unassisted MTB's above £2k have been on the decline sales wise for 5 years or more in the UK market, whilst during the same period eMTB's have seen continual growth until 2023 when they have plateaued somewhat. For sure, there is some lag behind shop floor sales and what is witnessed in trail centre car parks percentage wise,  but rest assured that sales wise, unassisted MTB's above a certain price point have been a minority for a number of years now rather than the majority...
You may not like these facts, and may wish to dispute them (hell, I'm sure there are people that have posted on this thread already that "know" I am talking bollocks, but they are probably the same people that said disc brakes would never have any place on road bikes, electronic gears would never take off, dropper posts were only for people who didn't have the skills to descend properly already and that 29er wheels on MTB's were the work of the devil!), but here we are, with me whose job it is to keep my finger on the pulse of the industry and report back the findings, telling you that for 4yrs running (2019-22 inclusive) eMTB's saw a significant rise in sales in the UK where unassisted MTB's above about £2k saw a significant downturn in sales at the same time.
FWIW, STW does not represent a particularly honest representation of the market as a whole... Why? You tell me... Maybe the typical person who has £5k+ to spend on an eBike doesn't have the time to spend perusing the internet all day picking arguments with people they don't know...? Who knows...
I've been riding MTB for over 30yrs. I will never not have a conventional unassisted bike in my fleet, and subjectively I still prefer the feeling of riding a lightweight unassisted bike on trails than I do a heavier eMTB on the same trails... But there's no argument against eMTB's allowing us to ride further, or faster, or more often, or without excuses that simply makes them more popular and more accessible for those with the means to own one!
Posted : 26/12/2023 10:09 pm
StuE and StuE reacted
You were doing so well and then you said you have a fleet.
Posted : 26/12/2023 10:28 pm
dissonance, CheesybeanZ, CheesybeanZ and 1 people reacted
If you are going to lead with this possibly best not to double down on it yourself.
whilst during the same period eMTB’s have seen continual growth until 2023 when they have plateaued somewhat
Not overly useful when we are considering a new product. What you have just said is a market going from emerging to growth to mature.
but rest assured that sales wise, unassisted MTB’s above a certain price point have been a minority for a number of years now rather than the majority…
isnt that pretty much by definition since to get the same capability in an e-bike it will be going into that "certain price point"? A half decent hardtail emtb will cost the same as my pretty decent full sus and
I guess if I could be arsed spending 5k I would have a motor in it or just do the job fully and go for a motorbike.
That said when I was at whinlatter midweek I did seem to be the only one on a nonelectric bike. Oddly didnt see any elsewhere during that week though.
Posted : 26/12/2023 10:34 pm
Is that a trail centre type place where it's up/down the up/down repeat? These are the places where, for me anyway, ebikes excell, just wallop up, fly down, back up, down etc etc. it's the whole ethos of them imo.
A nice ride and day out with rolling hills, I'm not as convinced.
That said, after Afan today on the MTB, I .ay Eeb it tomorrow if the knee plays up.
Posted : 26/12/2023 10:43 pm
 copa
I agree with this.
I would guess that the people on STW who don't own ebikes are becoming the minority.
And as we're 10 pages in, it's time to talk about capitalism and its unwavering ability to create great things and then to destroy them.
Who would have thought that the big problem that needed solving in mountain bikes was the need to pedal them? That feature of a bicycle that makes it so beautifully simple, healthy, affordable and efficient.
Hey ho.
Posted : 26/12/2023 10:44 pm
dander, funkmasterp, funkmasterp and 1 people reacted
And as we’re 10 pages in, it’s time to talk about capitalism
Is it? Can't we just talk bikes? Keep it bikey and forget everything else. You're thinking too deeply
Posted : 26/12/2023 10:48 pm
crossed, StuE, crossed and 1 people reacted
 copa
Can’t we just talk bikes? Keep it bikey and forget everything else. You’re thinking too deeply
Sorry to have disturbed you.
Maybe buy yourself a new bike to take your mind off it.
Posted : 26/12/2023 10:54 pm
I have a vision that humans will evolve into Davros. Ebikes are one step nearer 🙂
Posted : 26/12/2023 10:55 pm
supernova and supernova reacted
Lol that it? We're going to start having a pop if you don't like it? Stop being silly.
It's a bike forum, let's talk bikes. Keep your political ideal to somewhere else
Posted : 26/12/2023 10:58 pm
crossed, StuE, cogglepin and 3 people reacted
Well that’s killed the irony-meter.
Posted : 26/12/2023 11:43 pm
nickc and nickc reacted
Is that a trail centre type place where it’s up/down the up/down repeat?
Yeah and there are some pretty boring fireroad ascents but does mix it up a bit so not sure it ticks the wallop up and then down box.
I think it is as arguable for the rolling hills ride so long as the battery doesnt give out.
Posted : 27/12/2023 12:00 am
“Who would have thought that the big problem that needed solving in mountain bikes was the need to pedal them? That feature of a bicycle that makes it so beautifully simple, healthy, affordable and efficient.”
What makes an ebike so efficient is that you pedal it - and the motor helps as wanted/needed. If you step away from MTBing to general transport use the ebike has so much potential for the following reasons:
1. When it’s cold you can pedal harder to keep warm (ever commuted on a scooter or motorbike in the winter? You have to wear ALL the clothes and you still arrive frozen on cold days).
2. When it’s hot you can pedal softer so you don’t arrive a sweaty mess (we all know what it’s like when your destination is reached via an uphill).
3. When it’s hilly you can let the motor help so it’s more like walking to work (loads of people would choose to walk if they lived close enough). Riding bikes uphill is too much like sport for many people.
4. When there’s a strong headwind it’s no longer horrible (I like pedalling uphill on any bike but big headwinds are horrible).
5. When you’re tired or it’s a long way the motor can make it so much more pleasant - not everyone wants their commute to be a work-out.
We need the world to switch to more efficient forms of transport and the ebike is one of the most powerful tools to achieve that change. I see more and more older people out on bikes, both in town and the countryside and they’re usually on e-bikes. Yes, they’re still expensive and far from faultless but I believe they’re a very good thing.
Posted : 27/12/2023 12:12 am
ngnm, thols2, ngnm and 1 people reacted
Yep, they make a lot of sense for commuting. I’d rather go road riding than get one for mountain biking though, I want to get to the top, knock off big loops under my own power, others aren’t as bothered, and that’s fine.
Posted : 27/12/2023 12:43 am
supernova, funkmasterp, dissonance and 3 people reacted
And as we’re 10 pages in, it’s time to talk about capitalism and its unwavering ability to create great things and then to destroy them.
Oh here we go. Ebikes are the destroyers of society.
Copa
Come the revolution brother Copa, our glorious comrade chairman will make us all equal by mandating unassisted pedal bikes. I'm sure it will all be perfect when you're in charge!
Posted : 27/12/2023 12:56 am
I would guess that the people on STW who don’t own ebikes are becoming the minority
lolz
Posted : 27/12/2023 1:10 am
I would guess that the people on STW who don’t own ebikes are becoming the minority.
ANd the only bike I ride puts me in a tiny minority of that minority. I can however see the appeal and benefits of them to many people so rather than giving up it should just be making things easier while still riding.
At 55 I don't want to make things easier for the type of riding I do but I may do when I am 65 so I would buy one without feeling like I was giving up.
Posted : 27/12/2023 8:54 am
Ebikes, especially emtb, are gopping to look at.
Posted : 27/12/2023 9:04 am
north of the border, supernova, jameso and 5 people reacted
I won't buy one because we're clearly due a massive solar flare soon, this I believe will render them all useless. Explain that one smartasses!
Posted : 27/12/2023 9:13 am
tjagain and tjagain reacted
Those of us that work in the industry and are aware of purchasing trends know that unassisted MTB’s above £2k have been on the decline sales wise for 5 years or more in the UK market, whilst during the same period eMTB’s have seen continual growth until 2023 when they have plateaued somewhat.
Based on seeing/hearing trying to sell decent spec MTB's, seems right.
I did nearly 30 miles and 4500ft on mine yesterday, rode from home, met a few pals and rode our local trails (some natural, some built).
Before I bought the eeb I did equivalent rides on my non-eebs (which I still have) but yesterday rather than pushing up some of the climbs (it was very muddy), I rode them.
My Kenevo SL?  Looks like an Enduro IMO, or are you someone who's still on canti's?
Posted : 27/12/2023 9:19 am
https://twitter.com/fesshole/status/1739925342842704282
Posted : 27/12/2023 9:28 am
flyingpotatoes, doomanic, nickc and 5 people reacted
MTBs over £2000 would be a small part of the bikes sold surely?
Posted : 27/12/2023 9:33 am
thols2, funkmasterp, funkmasterp and 1 people reacted
Lumping like, a third of your body weight, over your head, when it’s an awkward shape and flaps around, is not to be sniffed at.
If you're having issues with your head flapping around, you probably need to look hard at your core neck strength or wear a lighter helmet. I'm not sure you can do much about head shape without drastic surgery mind 🙂
If you think differently then please can we do the four passes next spring for a laugh. I want to see this…
I'm very much looking forward to this, though I won't be on an e-mtb. Wasn't there a STW video of something similar?
Posted : 27/12/2023 10:13 am
It's true, most of them do look terrible with their oversized TT and BB areas. Especially those Haibikes. The only one I've seen that looks good is the Orbea Rise.
Posted : 27/12/2023 10:14 am
Posted : 27/12/2023 10:26 am
sirromj and sirromj reacted
They look like pregnant fish to me. That’s all I can see when I look at an eMTB for some reason. Honestly can’t believe this has made it to ten pages. I’m desperately thinking of something to enrage the hardliners on both sides of the debate to keep this going. 🤔
Posted : 27/12/2023 12:27 pm
To me they look like the van and 4X4 driving tubbies dressed in the latest of road pyjams who ride them, Then you look at the people who arrive in vans and 4X4s with other sorts of bike and they look just the same.
PS. I am old, overweight and slow. I can't lift heavy weights above my head and spring over gates and deer fences.
Just smile and wave 🙂
Posted : 27/12/2023 12:38 pm
I am getting old, I’m out of shape and could stand to lose a bit of lard. I have caveman genes though and can lift heavy unwieldy objects and carry them about relatively easily. I especially like how people have explained to me that carrying bikes across obstacles can be difficult. Like I’ve never done so in all my years of riding 😂
The HSE diagrams posted by TJ are eye opening. One suspects that the weights are so low to protect employers. Could just be me being cynical though.
Posted : 27/12/2023 1:52 pm
Sometimes it's not about what you can do , but what you choose to do.
I am 70 I go cycling and sea kayaking and can get my bikes and kayaks on the car by myself.
I don't do this because being slightly more evolved I don't risk injury unless I there is no viable alternative.
I can get a normal bike over  a locked deer fence but I doubt I could do this with a heavy bike.
Posted : 27/12/2023 2:04 pm
No - I said lifting an ebike over a fence is difficult for me*.  How can I possibly comment on others?   Just because I dont want to make a particular purchase is not equal to condemning anyone else who does.  Likewise why should I be told to get one. Honestly, I am fine with them - would love to give one a go but not in the market for one just yet.
* well I could do it, it would hurt, but unless you reverse the arrow of time, not for much longer.
Posted : 27/12/2023 2:23 pm
 mboy
A tongue in cheek comment I made on purpose, precisely to catch out the "offended by everything, holier than thou" contingent... I didn't expect to get a bite in the very next comment mind!
Ah yes... Michael Gove's "we're all tired of experts" argument... Nice try!
Correct... But it does seem you like to ignore any context to get your point across... Where the eMTB market above a certain price point (I did also say "above £2k" elsewhere in my last post) have been growing then maturing, conventional unassisted MTB's have been in decline all the while. There was certainly a spike in demand for sub £2k conventional MTB's in 2020-21, but that demand rapidly died off once the market was saturated and is now evidenced by shops selling stock off crazily cheap in many cases.
You are aware that you can't ride a motorbike (electric or otherwise) on MTB trails right...? Or in fact many places other than the UK road network (and some approved bridleways in Wales). Or are you just being obtuse for the sake of it...?
It has been said many times on this thread already, but I will repeat once more as clearly the point isn't getting through to some... eMTB's still need pedalling! They don't have a throttle, they don't do the work for you, they merely provide you with some assistance when you start doing the work yourself...
5yrs ago I'd have agreed firmly... Todays current crop of eBikes, most of them you can barely tell they have a motor or battery fitted from a silhouette.
I guess if you only find old school skinny tubed steel hardtail frames attractive then no eBike is likely to satisfy your taste buds, but my Orbea Rise has a slimmer downtube than many unassisted bikes and an almost entirely hidden motor. My GF couldn't believe it was actually an eBike when she first saw it... There are bikes out there with the latest TQ motor that is entirely concentric to the BB axle that you cannot tell they are an eBike at all until you notice a display or any extra buttons on the bars or top tube.
Bikes sold overall...? Or MTB's sold overall? The sub £2k MTB market saw a massive boom in 2020-21 due to COVID, but this sector became quite oversupplied and as such this sector has taken quite a dive through 2022-23. I don't have the data to hand right now (it is available from the Bicycle Association for anybody that wished to get access to it) but you would probably be surprised how expensive average bike sales are these days... Though I should qualify, the data doesn't include Supermarket BSO's which would obviously alter the balance somewhat...
I won’t buy one because we’re clearly due a massive solar flare soon, this I believe will render them all useless. Explain that one smartasses!
It's a calculated risk that many of us have chosen to take... People still buy houses on flood plains understanding the potential pitfalls, which puzzles me far more and is likely to be a more immediate issue...
Where would the world be without stereotypes...? No, seriously... Where would we be?
Personally I don't judge others for how they derive their enjoyment (unless it is derived at someone else's expense). There are people in this world who enjoy country music, football, or even reality TV... All things I actively avoid, but there are many more people in the world that enjoy these things than do riding MTB's, so I find it best not to judge...
Posted : 27/12/2023 3:05 pm
"Methinks the fella doth protest too much"
From both sides of course
Posted : 27/12/2023 3:16 pm
Those of us that work in the industry and are aware of purchasing trends know that unassisted MTB’s above £2k have been on the decline sales wise for 5 years or more in the UK market, whilst during the same period eMTB’s have seen continual growth until 2023 when they have plateaued somewhat. For sure, there is some lag behind shop floor sales and what is witnessed in trail centre car parks percentage wise, but rest assured that sales wise, unassisted MTB’s above a certain price point have been a minority for a number of years now rather than the majority…
You may not like these facts, and may wish to dispute them (hell, I’m sure there are people that have posted on this thread already that “know” I am talking bollocks, but they are probably the same people that said disc brakes would never have any place on road bikes, electronic gears would never take off, dropper posts were only for people who didn’t have the skills to descend properly already and that 29er wheels on MTB’s were the work of the devil!), but here we are, with me whose job it is to keep my finger on the pulse of the industry and report back the findings, telling you that for 4yrs running (2019-22 inclusive) eMTB’s saw a significant rise in sales in the UK where unassisted MTB’s above about £2k saw a significant downturn in sales at the same time.
FWIW, STW does not represent a particularly honest representation of the market as a whole… Why? You tell me… Maybe the typical person who has £5k+ to spend on an eBike doesn’t have the time to spend perusing the internet all day picking arguments with people they don’t know…? Who knows…
I’ve been riding MTB for over 30yrs. I will never not have a conventional unassisted bike in my fleet, and subjectively I still prefer the feeling of riding a lightweight unassisted bike on trails than I do a heavier eMTB on the same trails… But there’s no argument against eMTB’s allowing us to ride further, or faster, or more often, or without excuses that simply makes them more popular and more accessible for those with the means to own one!
That's some serious verbal commitment right there, but I'm struggling to see what the relevance is to the OP's question.
Just because shit loads of people do something doesn't mean that something is the apotheosis of its genre.... Eg Greggs and Macdonalds.
Posted : 27/12/2023 3:31 pm
thols2, dissonance, dissonance and 1 people reacted
 copa
It has been said many times on this thread already, but I will repeat once more as clearly the point isn’t getting through to some… eMTB’s still need pedalling!
They do because that's mechanically what's required for the motor to work.
But whenever any kind of substantial effort is required, such as going up a mountain, people are doing little more than waggling their legs.
Posted : 27/12/2023 3:37 pm
 but I’m struggling to see what the relevance is to the OP’s question.
I think the thread stopped having any relevance to the OP's question a number of pages ago.
Posted : 27/12/2023 3:39 pm
ngnm, doomanic, fettlin and 9 people reacted
At the end of the day it's riding a bike and any bike is fun.
It's just that sometimes you don't realise it's fun until later.
Ride whatever pleases you.
Posted : 27/12/2023 3:45 pm
At the end of the day it’s riding a bike and any bike is fun.
[tongue in cheek] NO @bruce, you are enjoying yourself in a way that some other people don't approve of. How very dare you go about your own business without first consulting them about how you should enjoy your own time. [/tongue in cheek]. You must suffer to have them wag their fingers at you and scowl disapprovingly.
Posted : 27/12/2023 3:51 pm
ngnm, funkmasterp, StuE and 3 people reacted
Page 5 / 10
