In terms of pedalling? Obviously the bike is static compared to rollers which is actually riding a bike, but rollers don't have any resistance on them, so would a turbo with no resistance (wheel not on the roller bit) be similar?
No because the rollers turn the front wheel via a band to give some resistance
Ok, thanks...I'd best get an old tyre on the bike then!
What kilo said, rollers have some resistance, enough for steady state stuff, maybe 400-500W where a turbo might absorb 1500-2500W in a sprint.
With more expensive rollers you can buy extra sets of drums, smaller diameters add more resistance as they have to spin faster.
Lol I can't push 500 watts for more then about 3 minutes and my ftp is a respectable 330w.
More like about 60-100 from rollers
๐ฏ
Mine probably feel closer to 250-300 pushing a big gear at a sensible cadence. I'd agree with about 500 watts if sprinting, but probably need to get to about 150rpm plus.
The band isn't there for resistance is for stability other wise the front wheel is static and you can't steer to keep upright. Resistance is from the drums themselves.
FWIW my current rollers (plastic drum things) top out at about 300-350 watts (53x12, 150 rpm).
But I can pick the whole assembly up and walk around with it.)
The previous ones I had (pretty much solid aluminium ones) would go to far more. I couldn't actually get to 53x12, 150rpm without a full on stand up effort, which i wasn't good enough at rollers to do. (They also weighed as much as a small planet, well 40-50 kilos, big steel frame.......)
Ironically enough, I am now good enough top do the whole stand up efforts. But can't justify spending that much on rollers. If they even make them anymore. (It's probably 25 years since I last saw a set)
And the resistance is hugely dependant on tyre pressure. Just going from 7 bar to 6 is enough to up the resistance noticeably.
