Is 7sp casette spac...
[Closed] Is 7sp casette spacing the se as 8sp ?
Is the spacing on a 7 speed casette (or freewheel) the same as on an 8 speed casette?
I want to know if I can use my old 8 speed shifters on my wife's old 7 speed bike.
Thanks.
Posted : 25/04/2014 3:44 pm
I'm sure it is.. I had a lovely set of 7 speed wheels to fit to an 8 speed set up and just dialled out the 8th click via rear mech ๐Ÿ™‚
Don't know if this answers question though !!
Posted : 25/04/2014 3:50 pm
yeah the spacing for the shifters is for shimano stuff at least.. Ive never had any issues running 8 speed shifters with 7 speed cassette.
for the change to 7 to 8 speed they just widened the freehub and popped an extra cog in..
everything since has just made everything thinner in the same space as an 8 speed cassette.
Posted : 25/04/2014 4:03 pm
8sp spacing for shimano differs from 7sp.
that's why the usual trick to "upgrade" 7speed stuff is to take a 9sp cassette, bin 1 sprocket, and run it 8sp with 9sp shifters+mech.
Posted : 25/04/2014 4:14 pm
No it really doesn't.
7 and 8 speed have the same spacing, just the 7 speed cassette is 1 cog& spacer narrower.
9 speed cassettes (and 10 for that matter) are the same width as 8 but with narrower spacing.
So TL:DR 8 speed shifters will work fine on a 7 speed cassette, you'll just have an unused click .
Posted : 25/04/2014 4:25 pm
"that's why the usual trick to "upgrade" 7speed stuff is to take a 9sp cassette, bin 1 sprocket, and run it 8sp with 9sp shifters+mech."
so after buying everything else 9 speed you throw a sprocket away to save the cost of a hub.
certainly was never a normal trick where i worked.
Posted : 25/04/2014 4:30 pm
shifter pull might be the same
some one better tell the late Sheldon Brown about 4.8mm spacing being equal to 5mm spacing then ๐Ÿ˜‰
Posted : 25/04/2014 4:31 pm
Have you ever actually tried this? In real life? With real parts?
EDIT - the 7/8 speed compatability, not the bodging a 9 speed cassette onto a 7 speed freehub.
Posted : 25/04/2014 4:40 pm
Update Preview
Hmmm. Some interesting discussion there.
I checked the good old Sheldon Brown website and it definitely suggests that I need an "alternate cable routing" to get the 8 speed shifters to work perfectly with the 7 speed freewheel.
http://sheldonbrown.com/derailer-adjustment.html#alternate
But I am guessing it will probably work ok (but not perfect) with just the normal routing. The spacing difference is only 0.2mm per shift. If I get the middle rear sprocket perfect, it will only be fractionally (0.6mm) out for the largest and smallest rear sprockets. And they won't get used much.
Posted : 26/04/2014 4:15 am
It'll work fine - I've done it many times with mismatched BSO's coming through the workshop. Shifting will be pretty much what you'd expect from a cheap 7 speed setup ๐Ÿ˜‰
Posted : 26/04/2014 10:17 am
I used 8 speed Shimano bar cons for years on 7 speed cassettes thinking they were also 7 speed. Zero issues in real life. The 0.2mm per click must be taken up by the wobbly top jockey wheel on the der as there's no evidence it's even there.
Posted : 26/04/2014 11:25 am
Yep, it'll work fine. Still running 7 & 8 speed here on the mountain bikes.
Posted : 26/04/2014 12:21 pm
