Installing starfang...
[Closed] Installing starfangle nut - Any tips?
 Earl
Or is this best done at a LBS
Posted : 29/07/2009 2:25 pm
Ditch the SFN and get one of these instead
http://www.chainreactioncycles.com/Models.aspx?ModelID=911
Posted : 29/07/2009 2:26 pm
buy the tool, it can be done with a hammer, but its a PITA and never quite goes in straight.
It's pretty easy to f&*k it up, but then again it's a pretty easy thing to do. Straight is more important than depth, so lots of little taps rather than a couple of big wallops and "oooops..." Mind you, it takes a bit of a whack to get them started.
Reading that back, that's not the best advice that's ever been handed out.
Posted : 29/07/2009 2:28 pm
 Smee
Hope head doctor is the biggest peice of crap i've ever purchased and with mountain biking kit that is some achievement.
Posted : 29/07/2009 2:30 pm
Use a long bolt and top cap with a raised stem as a guide.
Posted : 29/07/2009 2:34 pm
Tip: if using a hammer, screw a bolt into it first!
Posted : 29/07/2009 2:35 pm
 D0NK
Bit of a long winded way of doing it but it works well.
Get a threaded bar longer than your steerer and the same size* as your SFN with a couple of nuts locked against each other at one end with a big washer. Put threaded bar through steerer, washer and locknuts at the bottom, thread SFN on the top untill it butts up to the steerer then use a spanner to 'wind' the SFN down into the steerer.
I'm probably not explaining this very well am I?
Like I said its a bit slow but better than using a hammer as you're less likely to mess it up. As a bonus you can use the threaded bar and washers as a headset press too also if you don't have a spare SFN handy you can use this to tension the stem and bearings (and remove before riding obviously)
*i dunno what the proper term is
Posted : 29/07/2009 3:01 pm
 D0NK
Oh and continuing the theme of re-using stuff, head doctors (or certainly the similar design cheapo one I had) can be used as a bearing puller to get those external BB bearings out of their cups - with 3 hands a load of wooden spacers and lots of swearing aswell of course ๐Ÿ™‚ but for actually tensioning your headset they can be fiddly buggers
Posted : 29/07/2009 3:08 pm
 Earl
Thanks folks. I think I'll try DONK's idea. Cheers
Posted : 29/07/2009 3:24 pm
just hit it with a hammer & then a screwdriver to straighten it up when it goes wonky.
Posted : 29/07/2009 3:57 pm
15mm copper pipe offcut used as a drift (hit it with hammer) for me, the more you do with the same bit of pipe the better it gets as the end moulds to shape.
Posted : 29/07/2009 4:01 pm
I asked this a few weeks ago and bought the tool, glad I did, so easy to use
Tracey
Posted : 29/07/2009 4:07 pm
