Inbred SS hub freew...
[Closed] Inbred SS hub freewheel removal - help!
I have a Pompino, which came with the standard Inbred flip/flop hub.
I put a 16t freewheel on the screw-on side. Oodles of copperslip etc, so it hasn't seized.
I now want to change the freewheel to a 20t.
Unfortunately, because of what appears to be the design of the hub, I can't get the 16t off.
This is the freewheel on the hub:
http://jakestacey.fotopic.net/p57784975.html
This is a rather shakey pic of the Park FR-6 tool, attempting to remove the freewheel. It can't actually reach the splines, because of the cones.
http://jakestacey.fotopic.net/p57784976.html
So, you think - remove the cones.
But you can't do that, because there isn't enough clearance to get the cone spanner in around the freewheel:
http://jakestacey.fotopic.net/p57784977.html
What do I do? It feels very much like a Catch-22 situation.
I have tried various spanners and mole grips, but they haven't worked either.
I don't particular want to destroy the freewheel, but will if I have to. I can't see any way of getting the outer cover off though - because of those blasted cones!
Any ideas?
Posted : 26/04/2009 11:09 am
Can you take the cones off the other end of the axle, and then slide the axle out?
Posted : 26/04/2009 11:26 am
I have seen removal tools that were significantly deeper than that Park one, ask around at your LBS or look online.
Posted : 26/04/2009 11:37 am
Cheers DB - exactly what I need. Now, I wonder if my LBS would take back the Park one they sold me as 'perfect for the job'...
Posted : 27/04/2009 9:42 am
