Just picked up an 853 inbred sliding dropout frame. Because of the set-up with the sliding dropouts there's about a 1cm gap between the brake caliper fixing points and where the caliper needs to be.
It looks like I need some kind of spacer or adapter the same thickness as the dropout bit to align everyting - anyone else encountered this and found a fix?
Posted : 29/07/2012 7:55 pm
You got them with the frame (new) apparently! Had the same trouble when I bought mine second hand. You'll find that you can simply use a couple of those washer things that screw onto presta valves. Had mine running like that for a couple of years.
Posted : 29/07/2012 8:13 pm
Cheers vdub - i'll try the presta valve thing. Just need to find some longer bolts now!
Posted : 30/07/2012 12:40 pm
