Inbred - Front Mech...
[Closed] Inbred - Front Mech Slide-in Cable Boss Thingy
I managed to loose one mid build, I need another one but (probably because of lingo I am using) I can't find one on the On-One site. They also are too busy to take calls.
Can anyone shed some light?
Posted : 11/06/2012 10:16 am
One of [url= http://www.ebay.co.uk/itm/Bike-gear-cable-under-bottom-bracket-cable-guide-/180699104302 ]these?[/url]
Posted : 11/06/2012 10:21 am
do you have another you could do a pic of?
Posted : 11/06/2012 10:23 am
One of these?
Nope, its a small boss that slides into another boss on the frame, above the front mech. It mounts the front mech cable.
Posted : 11/06/2012 10:34 am
One of these?
http://www.chainreactioncycles.com/Models.aspx?ModelID=29462
PaulD
Posted : 11/06/2012 10:39 am
A Cable Stop. It fits into the last cable guide above the front mech.
Posted : 11/06/2012 10:40 am
Thats the badger. Searched on the on-one site with that and still can't find one :s
Posted : 11/06/2012 10:48 am
I have one - on an Inbred as it happens (hence I recognised what you were after).
Posted : 11/06/2012 10:49 am
I thought as much, thanks. All we need now is another one!
Posted : 11/06/2012 11:13 am
http://www.chainreactioncycles.com/Models.aspx?ModelID=12004
No longer available at CRC, but might help you find what you are after.
Posted : 11/06/2012 11:32 am
Looks like you will ned to buy the 4-pack I linked to earlier.
The Shimano ones do have a brass insert and a rubber seal, so with the noodle and rubber boot do an excellent job.
You can cut the noodle off for the ends at the shifter and rear mech.
I use SP41 outers, preferably full-length.
PaulD
Posted : 11/06/2012 1:19 pm
Paul - how do those Shimano ones work?
Posted : 11/06/2012 1:37 pm
PaulD
Hi Paul, aren't these purely for sealing the cables?
Posted : 11/06/2012 1:51 pm
Yes, these are cable-end sealed ferrules, recommended for SP41 outer.
You can keep or cut off the noodle and rubber boot as appropriate.
This link shows the sealed ferrule (without noodle and boot).
The 4-pack is Item 5 on this page...
I thought the split cable-stop was welded onto the frame.
The metal device in the picture is just an (overweight) alternative to mine.
PaulD
Posted : 11/06/2012 2:14 pm
